[GRASS-user] Problem with g.gui.tplot
leonardo sandon
leomadvr at gmail.com
Thu May 28 08:30:05 PDT 2015
Hi Veronica, hi everyone,
thanks for your answer.
For those who are interested on discover what is happening to my machine, I
link you a dropbox direction to download a "bite" of one of my strds which
are causing me the problem I wrote about.
There is also a collection of shp, that can be used to set the projection
(sinusoidal, Samson Flansted). Finally you'll find a graph made with
g.gui.tplot, just to compare yours to mine.
Thanks to all the willing! Greetings!
Leonardo
https://www.dropbox.com/sh/simz28i4qyajddc/AAB0_tAaEe8yWgbt1miIBeHCa?dl=0
2015-05-28 11:33 GMT-03:00 Veronica Andreo <veroandreo a gmail.com>:
> Ciao Leo!
> I cannot reproduce what you are observing in g.gui.tplot.
> I've tried with a strds of mine that has a lot of NULL values (set with
> r.null) and it looks good, as expected, where I have null values, i see a
> blank space in the plot...
> Can you send us a subset of the strds, upload it somewhere, or reproduce
> the example with North Carolina data set, so we can understand what's
> happening???
> ciao,
> Vero
> 2015-05-28 11:11 GMT-03:00 leonardo sandon <leomadvr a gmail.com>:
>> Hi guys!
>> I have a problem with gui.plot, or I should say, I have a suggestion for
>> the developpers.
>> This is a very useful tool, but it becomes quite unusable when in the
>> time series there are some null values (graph 1).
>> In fact in the graph, instead of not showing those values, they are
>> indicated as if they had a −2,147,483,648 value (long integer of C ISO/ANSI
>> C99 programming language?), and the resulting graph is pretty discouraging.
>> Even though there is the zoom tool to fit better to the good values, it is
>> not nice to see those vertical line (graph 2).
>> Is there any solution for that?
>> Greetings!
>> [image: Immagine in linea 1][image: Immagine in linea 2]
>> grass-user mailing list
>> grass-user a lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Un allegato HTML � stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150528/5f3cb741/attachment-0001.html>
Un allegato non testuale � stato rimosso....
Nome: graph1.png
Tipo: image/png
Dimensione: 84702 bytes
Descrizione: non disponibile
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150528/5f3cb741/attachment-0002.png>
Nome: graph2.png
Tipo: image/png
Dimensione: 86958 bytes
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150528/5f3cb741/attachment-0003.png>
