[GRASS-user] Problem with g.gui.tplot
    Veronica Andreo
    veroandreo at gmail.com
    Thu May 28 07:33:37 PDT 2015
Ciao Leo!
I cannot reproduce what you are observing in g.gui.tplot.
I've tried with a strds of mine that has a lot of NULL values (set with
r.null) and it looks good, as expected, where I have null values, i see a
blank space in the plot...
Can you send us a subset of the strds, upload it somewhere, or reproduce
the example with North Carolina data set, so we can understand what's
happening???
ciao,
Vero
2015-05-28 11:11 GMT-03:00 leonardo sandon <leomadvr at gmail.com>:
> Hi guys!
> I have a problem with gui.plot, or I should say, I have a suggestion for
> the developpers.
> This is a very useful tool, but it becomes quite unusable when in the time
> series there are some null values (graph 1).
> In fact in the graph, instead of not showing those values, they are
> indicated as if they had a −2,147,483,648 value (long integer of C ISO/ANSI
> C99 programming language?), and the resulting graph is pretty discouraging.
> Even though there is the zoom tool to fit better to the good values, it is
> not nice to see those vertical line (graph 2).
> Is there any solution for that?
> Greetings!
> [image: Immagine in linea 1][image: Immagine in linea 2]
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150528/d2831e72/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150528/d2831e72/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150528/d2831e72/attachment-0003.png>
