[GRASS-user] grass6.4.6 on debian 8
Vincent Bain
bain at toraval.fr
Fri Nov 6 13:01:09 PST 2015
Trying to install grass-6.4.6svn on a fresh debian jessie, I have no
errors during compilation/installation. But when I launch grass64, no
gui opens up, and I get the following error message on the terminal :
File
"/usr/local/grass-6.4.6svn/etc/wxpython/wxgui.py", line
34, in <module>
from lmgr.frame import GMFrame
File
"/usr/local/grass-6.4.6svn/etc/wxpython/lmgr/frame.py",
line 46, in <module>
from lmgr.layertree import LayerTree, LMIcons
File
"/usr/local/grass-6.4.6svn/etc/wxpython/lmgr/layertree.py", line 37, in <module>
from mapdisp.frame import MapFrame
File
"/usr/local/grass-6.4.6svn/etc/wxpython/mapdisp/frame.py", line 39, in <module>
from mapdisp.toolbars import MapToolbar, NvizIcons
File
"/usr/local/grass-6.4.6svn/etc/wxpython/mapdisp/toolbars.py", line 22, in <module>
from nviz.main import haveNviz
File
"/usr/local/grass-6.4.6svn/etc/wxpython/nviz/main.py",
line 24, in <module>
from nviz import mapwindow
File
"/usr/local/grass-6.4.6svn/etc/wxpython/nviz/mapwindow.py", line 42, in <module>
from nviz.workspace import NvizSettings
File
"/usr/local/grass-6.4.6svn/etc/wxpython/nviz/workspace.py", line 22, in <module>
from nviz import wxnviz
File
"/usr/local/grass-6.4.6svn/etc/wxpython/nviz/wxnviz.py",
line 49, in <module>
sys.stderr.write(_("3D view mode: %s\n") % e)
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3
in position 58: ordinal not in range(128)
I tried to rebuild after a distclean, even purged completely my svn src
directory, but the error is still the same.
Did anybody experience the same issue recently ?
Thanks,
Vincent.
