[GRASS-user] syntax for grass.run_command("v.rast.stat")
Anna Petrášová kratochanna at gmail.com
Fri Oct 23 10:07:01 PDT 2015
On Fri, Oct 23, 2015 at 10:31 AM, Gra <graziaz at gmail.com> wrote:
> I'm using
> v.rast.stat in a python code
> it's v.rast.stats and use map instead of vector, please see manual page:
https://grass.osgeo.org/grass70/manuals/v.rast.stats.html
> grass.run_command("v.rast.stat", vector = vect+"_"+suffix +'_300', raster=
> "r_main_roads_dist" + suffix, colprefix="AVG_mainroads", method="average")
> apparently it doens't like my syntax
> ideas?
> thanks
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151023/3d65137e/attachment.html>
