[GRASS-user] syntax for grass.run_command("v.rast.stat")
    Grazia Zulian
    graziaz at gmail.com
    Fri Oct 23 23:05:24 PDT 2015
Hi Anna
It should add a new field to a vector with a statistic derived from a raster.
It works manually. Not in the pytho scrip. Is the syntax correct?
Inviato da iPhone
> Il giorno 23/ott/2015, alle ore 19:07, Anna Petrášová <kratochanna at gmail.com> ha scritto:
>> On Fri, Oct 23, 2015 at 10:31 AM, Gra <graziaz at gmail.com> wrote:
>> I'm using
>> v.rast.stat in a python code
> it's v.rast.stats and use map instead of vector, please see manual page:
> https://grass.osgeo.org/grass70/manuals/v.rast.stats.html
>> grass.run_command("v.rast.stat", vector = vect+"_"+suffix +'_300', raster= "r_main_roads_dist" + suffix, colprefix="AVG_mainroads", method="average")
>> apparently it doens't like my syntax
>> ideas?
>> thanks
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151024/e74fb3b4/attachment.html>
