[GRASS-user] syntax for grass.run_command("v.rast.stat")
Helmut Kudrnovsky
hellik at web.de
Sat Oct 24 01:53:39 PDT 2015
Grazia Zulian wrote
> Hi Anna
> It should add a new field to a vector with a statistic derived from a
> raster.
> It works manually. Not in the pytho scrip. Is the syntax correct?
> Inviato da iPhone
>> Il giorno 23/ott/2015, alle ore 19:07, Anna Petrášová <
> kratochanna@
> > ha scritto:
>>> On Fri, Oct 23, 2015 at 10:31 AM, Gra <
> graziaz@
> > wrote:
>>> I'm using
>>> v.rast.stat in a python code
>> it's v.rast.stats and use map instead of vector, please see manual page:
>> https://grass.osgeo.org/grass70/manuals/v.rast.stats.html
>>> grass.run_command("v.rast.stat", vector = vect+"_"+suffix +'_300',
>>> raster= "r_main_roads_dist" + suffix, colprefix="AVG_mainroads",
>>> method="average")
>>> apparently it doens't like my syntax
>>> ideas?
as Anna mentioned in her reply:
the command is "v.rast.stats" and not as in your python code "v.rast.stat"
the second issue (also mentioned by Anna):
v.rast.stats vector=elev_wakes3 at user1 raster=elevation at PERMANENT
colprefix=rast_ave2 method=average
ERROR: v.rast.stats: Sorry, <vector> is not a valid
parameter
ERROR: Required parameter <map> not set:
(Name of vector map)
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/syntax-for-grass-run-command-v-rast-stat-tp5232220p5232312.html
Sent from the Grass - Users mailing list archive at Nabble.com.
