[GRASS-user] an error during running of module r.bioclim
Albert Saribekyan albertsaribekyan at rambler.ru
Fri Sep 4 06:36:52 PDT 2015
help me please to correct this mistake
r.bioclim
tmin=tmin1_17 �� PERMANENT,tmin2_17 �� PERMANENT,tmin3_17 �� PERMANENT,tmin4_17 �� PERMANENT,tmin5_17 �� PERMANENT,tmin6_17 �� PERMANENT,tmin7_17 �� PERMANENT,tmin8_17 �� PERMANENT,tmin9_17 �� PERMANENT,tmin10_17 �� PERMANENT,tmin11_17 �� PERMANENT,tmin12_17 �� PERMANENT
tmax=tmax1_17 �� PERMANENT,tmax2_17 �� PERMANENT,tmax3_17 �� PERMANENT,tmax4_17 �� PERMANENT,tmax5_17 �� PERMANENT,tmax6_17 �� PERMANENT,tmax7_17 �� PERMANENT,tmax8_17 �� PERMANENT,tmax9_17 �� PERMANENT,tmax10_17 �� PERMANENT,tmax11_17 �� PERMANENT,tmax12_17 �� PERMANENT
output=result
Unknown module parameter "keyword" at line 18
Unknown module parameter "keyword" at line 19
Calculating monthly averages from min and max
ERROR: Sorry, <pattern> is not a valid parameter
ERROR: Sorry, <separator> is not a valid parameter
ERROR: Value <raster> out of range for parameter <type>
Legal range: rast,rast3d,vect,oldvect,asciivect,icon
,labels,sites,region,region3d,group,view3d,all
BIO1 = Annual Mean Temperature ...
ERROR: Raster map not found
Invalid map <result.bio01.10012>
Parse error
ERROR: parse error
ERROR: An error occurred while running r.mapcalc
(Fri Sep 4 17:23:14 2015) Command finished (1 min 29 sec)
regards
Albert Saribekyan.
�������� � ������� HTML ���� ���������…
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150904/532fd4b6/attachment.html>
