[GRASS-user] an error during running of module r.bioclim
Markus Neteler neteler at osgeo.org
Fri Sep 4 11:00:04 PDT 2015
On Fri, Sep 4, 2015 at 3:36 PM, Albert  Saribekyan
<albertsaribekyan at rambler.ru> wrote:
> help me please to correct this mistake
> r.bioclim
> tmin=tmin1_17 at PERMANENT,tmin2_17 at PERMANENT,tmin3_17 at PERMANENT,tmin4_17 at PERMANENT,tmin5_17 at PERMANENT,tmin6_17 at PERMANENT,tmin7_17 at PERMANENT,tmin8_17 at PERMANENT,tmin9_17 at PERMANENT,tmin10_17 at PERMANENT,tmin11_17 at PERMANENT,tmin12_17 at PERMANENT
> tmax=tmax1_17 at PERMANENT,tmax2_17 at PERMANENT,tmax3_17 at PERMANENT,tmax4_17 at PERMANENT,tmax5_17 at PERMANENT,tmax6_17 at PERMANENT,tmax7_17 at PERMANENT,tmax8_17 at PERMANENT,tmax9_17 at PERMANENT,tmax10_17 at PERMANENT,tmax11_17 at PERMANENT,tmax12_17 at PERMANENT
> output=result
> Unknown module parameter "keyword" at line 18
> Unknown module parameter "keyword" at line 19
You need to run r.bioclim in GRASS GIS 7 (is it possible that you try
it in GRASS GIS 6?).
Best
Markus
