[GRASS-user] an error during running of module r.bioclim
    Albert  Saribekyan
    albertsaribekyan at rambler.ru
    Tue Sep  8 00:58:32 PDT 2015
I am already using GRASS GIS 7, see the attachment file
Albert  Saribekyan.
> 9/4/2015 11:00:26 PM пользователь Markus Neteler (neteler �� osgeo.org) написал:
> On Fri, Sep 4, 2015 at 3:36 PM, Albert    Saribekyan
> <albertsaribekyan �� rambler.ru> wrote:
> > help me please to correct this mistake
> > r.bioclim
> > tmin=tmin1_17 �� PERMANENT,tmin2_17 �� PERMANENT,tmin3_17 �� PERMANENT,tmin4_17 �� PERMANENT,tmin5_17 �� PERMANENT,tmin6_17 �� PERMANENT,tmin7_17 �� PERMANENT,tmin8_17 �� PERMANENT,tmin9_17 �� PERMANENT,tmin10_17 �� PERMANENT,tmin11_17 �� PERMANENT,tmin12_17 �� PERMANENT
> > tmax=tmax1_17 �� PERMANENT,tmax2_17 �� PERMANENT,tmax3_17 �� PERMANENT,tmax4_17 �� PERMANENT,tmax5_17 �� PERMANENT,tmax6_17 �� PERMANENT,tmax7_17 �� PERMANENT,tmax8_17 �� PERMANENT,tmax9_17 �� PERMANENT,tmax10_17 �� PERMANENT,tmax11_17 �� PERMANENT,tmax12_17 �� PERMANENT
> > output=result
> > Unknown module parameter "keyword" at line 18
> > Unknown module parameter "keyword" at line 19
> You need to run r.bioclim in GRASS GIS 7 (is it possible that you try
> it in GRASS GIS 6?).
> Best
> Markus
Name: Screenshot from 2015-09-08 11:56:32.png
Type: image/png
Desc: �����������
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150908/77c736fc/attachment-0001.png>
