[GRASS-user] Is it possible to export a vector as new table in existing spatialite database?
John A Stevenson
john.stevenson at ed.ac.uk
Sun Sep 6 14:43:45 PDT 2015
On 04/09/15 18:38, Markus Neteler wrote:
> On Fri, Sep 4, 2015 at 5:49 PM, John A Stevenson
> <john.stevenson at ed.ac.uk> wrote:
>> I would like to export a vector as new table in existing spatialite
>> database.
> Please let us know how it goes, then we may add that to the manual as
> a new example.
> Markus
When I tried exporting to Spatialite from GRASS using v.out.ogr, I got
an error, and although the table was created, the geometry didn't work.
(Example using nc_spm_08_grass7).
v.out.ogr --overwrite input=firestations at PERMANENT output=nc.sqlite
format=SQLite dsco=SPATIALITE=YES
Gives:
Exporting 71 features...
ERROR 1: sqlite3_step() failed:
firestations.GEOMETRY violates Geometry constraint [geom-
type or SRID not allowed] (19)
<... lots of these ...>
ERROR 1: COMMIT transaction failed: cannot commit - no
transaction is active
v.out.ogr complete. 71 features (Point type) written to <firestations>
(SQLite format).
(Sun Sep 6 22:07:37 2015) Command finished (3 sec)
The database is created, including a table with a GEOMETRY column, but
when I try to view it with the Map Preview in the spatialite_gui
software, it says "This Column doesn't contains any Geometry: sorry...".
However, if I export to a shapefile first then use ogr2ogr, it works:
output=nc_firestations.shp
v.out.ogr --overwrite input=geology at PERMANENT output=nc_geology.shp
ogr2ogr -f sqlite -dsco SPATIALITE=YES nc.sqlite nc_firestations.shp
ogr2ogr -f sqlite -dsco SPATIALITE=YES nc.sqlite nc_geology.shp -append
I'm not sure what is causing the error, but a Google search brings up a
ticket for an already existing bug:
https://trac.osgeo.org/grass/ticket/2300
If not the case of the GEOMETRY column, then perhaps it is the case of
the geometry type e.g. GRASS passes 'Point' but Spatialite wants 'POINT'?
I'm on GRASS 7.0.1 from the UbuntuGIS unstable repository.
Cheers
John
Dr John A Stevenson
RSE/Scottish Government Personal Research Fellow
(co-funded by Marie Curie Actions)
School of GeoSciences
The University of Edinburgh
Grant Institute
James Hutton Road
Edinburgh EH9 3FE
Scotland
PHONE: (+44) 131 650 7526
FAX: (+44) 131 668 3184
email:john.stevenson at ed.ac.uk
twitter: @volcan01010
web:http://www.geos.ed.ac.uk/homes/jsteven5
blog:http://all-geo.org/volcan01010
**ICELAND MOBILE: (+354) 8417106**
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
