[GRASS-user] Query vector type has problems
Andres Kuusk andres at to.ee
Wed Sep 9 08:00:55 PDT 2015
Hi!
>> Vector commands v.what.vect and v.distance do not fill the attribute
>>>> column of a point vector.
> it took me a while to figure out the problem, but it's because your samples
> are 3D and the stand vector is not. If you convert the samples to 2d with
> v.to.3d, then it will work.
Thank you!
Andres Kuusk
Tartu Observatory
