[GRASS-user] problem with t.rast.mapcalc (grass71 daily ubuntu 14.04)
Veronica Andreo veroandreo at gmail.com
Wed Sep 9 11:17:37 PDT 2015
Hi Leo,
Yes, I had the same problem some time ago and the solution was to change
the name, as you mentioned...
Maybe a bug? Dunno :)
Cheers,
Vero
El sep 9, 2015 3:05 PM, "Leonardo Hardtke" <leohardtke at gmail.com> escribió:
> Dear GRASS users (and developers?!),
> I'm facing a problem with an expression in the t.rast.mapcalc module...
> t.rast.mapcalc inputs=QA_mask,ndvi,ndvi_smooth_spacetime
> expression="if(QA_mask==0,ndvi,ndvi_smooth_spacetime)" output=ndvi_fixed
> basename=ndvi_fixed
> It throws the following error:
> Starting temporal sampling...
> Starting mapcalc computation...
> Invalid map
> <MOD13Q1.A2009017.h12v12.005.2009035110230_01_4326_smooth_spacetime_0>
> Parse error
> ERROR: parse error
> ERROR: Error while mapcalc computation
> The QA_mask maps are:
> QA_mask_01|PERMANENT|2009-01-01 00:00:00|2009-01-17 00:00:00
> QA_mask_02|PERMANENT|2009-01-17 00:00:00|2009-02-02 00:00:00
> The ndvi_smooth_spacetime maps are:
> ndvi_smooth_spacetime_0|PERMANENT|2009-01-17 00:00:00|2009-02-02 00:00:00
> ndvi_smooth_spacetime_1|PERMANENT|2009-02-02 00:00:00|2009-02-18 00:00:00
> The ndvi maps are
> MOD13Q1.A2009001.h12v12.005.2009019145228_01_4326|PERMANENT|2009-01-01
> MOD13Q1.A2009017.h12v12.005.2009035110230_01_4326|PERMANENT|2009-01-17
> M
> As you see, there is no such a map like..
> I guess the module is mixing ndvi (a temporal dataset) with
> _smooth_spacetime... the second part of the name....
> I know it work ok by renaming the ndvi_smooth_spacetime by something
> else... but... is this a bug or shoul I use more '`" to protect names !?
> Thanks!
> Dr. Leonardo A. Hardtke
> Laboratorio de Teledetección y S.I.G.
> Centro Nacional Patagónico (CONICET)
> Bvd. Brown 2825, 9120
> Puerto Madryn, Chubut, Argentina
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150909/81413bcd/attachment.html>
