[GRASS-user] problem with t.rast.mapcalc (grass71 daily ubuntu 14.04)
Leonardo Hardtke
leohardtke at gmail.com
Wed Sep 9 11:38:27 PDT 2015
Thaks
If it is a bug, I should fill a bug report so that some developer can fix
it!
Cheers
2015-09-09 15:17 GMT-03:00 Veronica Andreo <veroandreo at gmail.com>:
> Hi Leo,
> Yes, I had the same problem some time ago and the solution was to change
> the name, as you mentioned...
> Maybe a bug? Dunno :)
> Cheers,
> Vero
> El sep 9, 2015 3:05 PM, "Leonardo Hardtke" <leohardtke at gmail.com>
> escribió:
>> Dear GRASS users (and developers?!),
>> I'm facing a problem with an expression in the t.rast.mapcalc module...
>> t.rast.mapcalc inputs=QA_mask,ndvi,ndvi_smooth_spacetime
>> expression="if(QA_mask==0,ndvi,ndvi_smooth_spacetime)" output=ndvi_fixed
>> basename=ndvi_fixed
>> It throws the following error:
>> Starting temporal sampling...
>> Starting mapcalc computation...
>> Invalid map
>> <MOD13Q1.A2009017.h12v12.005.2009035110230_01_4326_smooth_spacetime_0>
>> Parse error
>> ERROR: parse error
>> ERROR: Error while mapcalc computation
>> The QA_mask maps are:
>> QA_mask_01|PERMANENT|2009-01-01 00:00:00|2009-01-17 00:00:00
>> QA_mask_02|PERMANENT|2009-01-17 00:00:00|2009-02-02 00:00:00
>> The ndvi_smooth_spacetime maps are:
>> ndvi_smooth_spacetime_0|PERMANENT|2009-01-17 00:00:00|2009-02-02 00:00:00
>> ndvi_smooth_spacetime_1|PERMANENT|2009-02-02 00:00:00|2009-02-18 00:00:00
>> The ndvi maps are
>> MOD13Q1.A2009001.h12v12.005.2009019145228_01_4326|PERMANENT|2009-01-01
>> MOD13Q1.A2009017.h12v12.005.2009035110230_01_4326|PERMANENT|2009-01-17
>> M
>> As you see, there is no such a map like..
>> I guess the module is mixing ndvi (a temporal dataset) with
>> _smooth_spacetime... the second part of the name....
>> I know it work ok by renaming the ndvi_smooth_spacetime by something
>> else... but... is this a bug or shoul I use more '`" to protect names !?
>> Thanks!
>> Dr. Leonardo A. Hardtke
>> Laboratorio de Teledetección y S.I.G.
>> Centro Nacional Patagónico (CONICET)
>> Bvd. Brown 2825, 9120
>> Puerto Madryn, Chubut, Argentina
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150909/ecaf3b3b/attachment.html>
