[GRASS-user] GRASS7-dev-error
Carmine Massarelli
carmine.massarelli at ba.irsa.cnr.it
Thu Sep 10 01:31:12 PDT 2015
hi dear,
when i launch the command i.gensigset i receive the error /'ascii' codec
can't decode byte 0xc3 in position 10: ordinal not in range(128). /This
error could compromise the sigfile?
I use grass-dev on ubuntu 14.04
Thanks
Dr. Nat. Carmine Massarelli, Ph.D. / Technologist
National Research Council - Institute of Water Research
Addr: Via De Blasio, n.5 - 70132 (Ba)
Un allegato HTML ? stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/fdb88370/attachment.html>
Un allegato non testuale ? stato rimosso....
Nome: spacer.gif
Tipo: image/gif
Dimensione: 1097 bytes
Descrizione: non disponibile
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/fdb88370/attachment.gif>
