[GRASS-user] GRASS7-dev-error
    Carmine Massarelli
    carmine.massarelli at ba.irsa.cnr.it
    Thu Sep 10 04:39:36 PDT 2015
Hi all,
i am receiving other error, this one when i digit /v.in.og/
/D1/5: grass.script.core.start_command(): g.gisenv -n//
//D1/5: G_set_program_name(): g.gisenv//
//D2/5: G_option_to_separator(): key = separator -> sep = '//
//Traceback (most recent call last)://
//  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 310, in
<lambda>//
//    lambda event: self.RunSpecialCmd(event.cmd))//
//  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 623, in
RunSpecialCmd//
//    self.OnImportOgrLayers(event = None, cmd = command)//
//  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 1691, in
OnImportOgrLayers//
//    dlg = GdalImportDialog(parent = self, giface = self._giface, ogr =
True)//
//  File "/usr/lib/grass70/gui/wxpython/gui_core/dialogs.py", line 1878,
in __init__//
//    " ({mightNotWork})".format(mightNotWork=mightNotWork)))//
//UnicodeEncodeError: 'ascii' codec can't encode character u'\xf9' in
position 37: ordinal not in range(128)/
Il 09/10/2015 10:31 AM, Carmine Massarelli ha scritto:
> hi dear,
> when i launch the command i.gensigset i receive the error /'ascii'
> codec can't decode byte 0xc3 in position 10: ordinal not in
> range(128). /This error could compromise the sigfile?
> I use grass-dev on ubuntu 14.04
> Thanks
> Dr. Nat. Carmine Massarelli, Ph.D. / Technologist
> National Research Council - Institute of Water Research
> Addr: Via De Blasio, n.5 - 70132 (Ba)
carmine.massarelli a ba.irsa.cnr.it <mailto:carmine.massarelli a ba.irsa.cnr.it>
Un allegato HTML ? stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/593c7535/attachment.html>
Un allegato non testuale ? stato rimosso....
Nome:        non disponibile
Tipo:        image/gif
Dimensione:  1097 bytes
Descrizione: non disponibile
URL:         <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/593c7535/attachment.gif>
Nome:        spacer.gif
Tipo:        image/gif
URL:         <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/593c7535/attachment-0001.gif>
