[GRASS-user] GRASS7-dev-error
Anna Petrášová kratochanna at gmail.com
Thu Sep 10 06:18:54 PDT 2015
On Thu, Sep 10, 2015 at 7:39 AM, Carmine Massarelli <
carmine.massarelli at ba.irsa.cnr.it> wrote:
> Hi all,
> i am receiving other error, this one when i digit *v.in.og*
> *D1/5: grass.script.core.start_command(): g.gisenv -n*
> *D1/5: G_set_program_name(): g.gisenv*
> *D2/5: G_option_to_separator(): key = separator -> sep = '*
> *Traceback (most recent call last):*
> *  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 310, in
> <lambda>*
> *    lambda event: self.RunSpecialCmd(event.cmd))*
> *  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 623, in
> RunSpecialCmd*
> *    self.OnImportOgrLayers(event = None, cmd = command)*
> *  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 1691, in
> OnImportOgrLayers*
> *    dlg = GdalImportDialog(parent = self, giface = self._giface, ogr =
> True)*
> *  File "/usr/lib/grass70/gui/wxpython/gui_core/dialogs.py", line 1878, in
> __init__*
> *    " ({mightNotWork})".format(mightNotWork=mightNotWork)))*
> *UnicodeEncodeError: 'ascii' codec can't encode character u'\xf9' in
> position 37: ordinal not in range(128)*
What version of grass do you use? You can find it in Help -> About system.
I believe this was fixed, see
https://trac.osgeo.org/grass/ticket/2720
Anna
> Il 09/10/2015 10:31 AM, Carmine Massarelli ha scritto:
> hi dear,
> when i launch the command i.gensigset i receive the error  *'ascii' codec
> can't decode byte 0xc3 in position 10: ordinal not in range(128). *This
> error could compromise the sigfile?
> I use grass-dev on ubuntu 14.04
> Thanks
> Dr. Nat. Carmine Massarelli, Ph.D. / Technologist
> National Research Council - Institute of Water Research
> Addr: Via De Blasio, n.5 - 70132 (Ba)
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/3e90954c/attachment-0001.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/3e90954c/attachment-0002.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/3e90954c/attachment-0003.gif>
