[GRASS-user] GRASS7-dev-error
Carmine Massarelli carmine.massarelli at ba.irsa.cnr.it
Thu Sep 10 06:31:55 PDT 2015
at the moment i am using 7.0.1 64 bit (not more dev) on ubuntu 14.04.
I saw the tickets, do you suggest me to change the file in the folder
//usr/lib/grass70/gui/?
In addition i have another error with i gengiset (it is unable to
produce sigfile reporting the error /'ascii' codec can't decode byte
0xc3 in position 10: ordinal not in range(128)/).
Thanks
Il 09/10/2015 03:18 PM, Anna Petrášová ha scritto:
> On Thu, Sep 10, 2015 at 7:39 AM, Carmine Massarelli
> <carmine.massarelli a ba.irsa.cnr.it
> <mailto:carmine.massarelli a ba.irsa.cnr.it>> wrote:
>     Hi all,
>     i am receiving other error, this one when i digit /v.in.og/
>     /D1/5: grass.script.core.start_command(): g.gisenv -n//
>     //D1/5: G_set_program_name(): g.gisenv//
>     //D2/5: G_option_to_separator(): key = separator -> sep = '//
>     //Traceback (most recent call last)://
>     //  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 310,
>     in <lambda>//
>     //    lambda event: self.RunSpecialCmd(event.cmd))//
>     //  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 623,
>     in RunSpecialCmd//
>     //    self.OnImportOgrLayers(event = None, cmd = command)//
>     //  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 1691,
>     in OnImportOgrLayers//
>     //    dlg = GdalImportDialog(parent = self, giface = self._giface,
>     ogr = True)//
>     //  File "/usr/lib/grass70/gui/wxpython/gui_core/dialogs.py", line
>     1878, in __init__//
>     //    " ({mightNotWork})".format(mightNotWork=mightNotWork)))//
>     //UnicodeEncodeError: 'ascii' codec can't encode character u'\xf9'
>     in position 37: ordinal not in range(128)/
> What version of grass do you use? You can find it in Help -> About system.
> I believe this was fixed, see
> https://trac.osgeo.org/grass/ticket/2720
> Anna
>     Il 09/10/2015 10:31 AM, Carmine Massarelli ha scritto:
>>     hi dear,
>>     when i launch the command i.gensigset i receive the error
>>     /'ascii' codec can't decode byte 0xc3 in position 10: ordinal not
>>     in range(128). /This error could compromise the sigfile?
>>     I use grass-dev on ubuntu 14.04
>>     Thanks
>>     Dr. Nat. Carmine Massarelli, Ph.D. / Technologist
>>     National Research Council - Institute of Water Research
>>     Addr: Via De Blasio, n.5 - 70132 (Ba)
>     _______________________________________________
>     grass-user mailing list
>     grass-user a lists.osgeo.org <mailto:grass-user a lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/grass-user
carmine.massarelli a ba.irsa.cnr.it <mailto:carmine.massarelli a ba.irsa.cnr.it>
Un allegato HTML � stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/cb8fccc0/attachment.html>
Un allegato non testuale � stato rimosso....
Nome:        non disponibile
Tipo:        image/gif
Dimensione:  1097 bytes
Descrizione: non disponibile
URL:         <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/cb8fccc0/attachment.gif>
Tipo:        image/gif
URL:         <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/cb8fccc0/attachment-0001.gif>
Nome:        spacer.gif
Tipo:        image/gif
URL:         <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/cb8fccc0/attachment-0002.gif>
