[GRASS-user] GRASS7-dev-error
    Anna Petrášová
    kratochanna at gmail.com
    Thu Sep 10 06:35:58 PDT 2015
On Thu, Sep 10, 2015 at 9:31 AM, Carmine Massarelli <
carmine.massarelli at ba.irsa.cnr.it> wrote:
> at the moment i am using 7.0.1 64 bit (not more dev) on ubuntu 14.04.
> I saw the tickets, do you suggest me to change the file in the folder
> */usr/lib/grass70/gui*?
> In addition i have another error with i gengiset (it is unable to produce
> sigfile reporting the error *'ascii' codec can't decode byte 0xc3 in
> position 10: ordinal not in range(128)*).
> Thanks
I am little bit confused what are the options on ubuntu, perhaps there is a
repository with daily builds? You can change the python files in your
current installation or you can compile grass yourself, which is not too
difficult.
About the other error, I don't know, perhaps you could file a ticket and
describe there the exact steps how to reproduce it? And add the debug
output.
Anna
> Il 09/10/2015 03:18 PM, Anna Petrášová ha scritto:
> On Thu, Sep 10, 2015 at 7:39 AM, Carmine Massarelli <
> <carmine.massarelli at ba.irsa.cnr.it>carmine.massarelli at ba.irsa.cnr.it>
> wrote:
>> Hi all,
>> i am receiving other error, this one when i digit *v.in.og*
>> *D1/5: grass.script.core.start_command(): g.gisenv -n*
>> *D1/5: G_set_program_name(): g.gisenv*
>> *D2/5: G_option_to_separator(): key = separator -> sep = '*
>> *Traceback (most recent call last):*
>> *  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 310, in
>> <lambda>*
>> *    lambda event: self.RunSpecialCmd(event.cmd))*
>> *  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 623, in
>> RunSpecialCmd*
>> *    self.OnImportOgrLayers(event = None, cmd = command)*
>> *  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 1691, in
>> OnImportOgrLayers*
>> *    dlg = GdalImportDialog(parent = self, giface = self._giface, ogr =
>> True)*
>> *  File "/usr/lib/grass70/gui/wxpython/gui_core/dialogs.py", line 1878,
>> in __init__*
>> *    " ({mightNotWork})".format(mightNotWork=mightNotWork)))*
>> *UnicodeEncodeError: 'ascii' codec can't encode character u'\xf9' in
>> position 37: ordinal not in range(128)*
> What version of grass do you use? You can find it in Help -> About system.
> I believe this was fixed, see
> https://trac.osgeo.org/grass/ticket/2720
> Anna
>> Il 09/10/2015 10:31 AM, Carmine Massarelli ha scritto:
>> hi dear,
>> when i launch the command i.gensigset i receive the error  *'ascii'
>> codec can't decode byte 0xc3 in position 10: ordinal not in range(128). *This
>> error could compromise the sigfile?
>> I use grass-dev on ubuntu 14.04
>> Thanks
>> Dr. Nat. Carmine Massarelli, Ph.D. / Technologist
>> National Research Council - Institute of Water Research
>> Addr: Via De Blasio, n.5 - 70132 (Ba)
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/381a5886/attachment-0001.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/381a5886/attachment-0003.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/381a5886/attachment-0004.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/381a5886/attachment-0005.gif>
