[GRASS-user] GRASS7-dev-error
Anna Petrášová kratochanna at gmail.com
Thu Sep 10 08:15:37 PDT 2015
On Thu, Sep 10, 2015 at 9:35 AM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Thu, Sep 10, 2015 at 9:31 AM, Carmine Massarelli <
> carmine.massarelli at ba.irsa.cnr.it> wrote:
>> at the moment i am using 7.0.1 64 bit (not more dev) on ubuntu 14.04.
>> I saw the tickets, do you suggest me to change the file in the folder
>> */usr/lib/grass70/gui*?
>> In addition i have another error with i gengiset (it is unable to produce
>> sigfile reporting the error *'ascii' codec can't decode byte 0xc3 in
>> position 10: ordinal not in range(128)*).
>> Thanks
> I am little bit confused what are the options on ubuntu, perhaps there is
> a repository with daily builds? You can change the python files in your
> current installation or you can compile grass yourself, which is not too
> difficult.
> About the other error, I don't know, perhaps you could file a ticket and
> describe there the exact steps how to reproduce it? And add the debug
> output.
I suggested to open a ticket on the other problem with i.gensigset. I
closed the ticket you opened because it's a duplicate (and solved already).
Anna
> Anna
>> Il 09/10/2015 03:18 PM, Anna Petrášová ha scritto:
>> On Thu, Sep 10, 2015 at 7:39 AM, Carmine Massarelli <
>> <carmine.massarelli at ba.irsa.cnr.it>carmine.massarelli at ba.irsa.cnr.it>
>> wrote:
>>> Hi all,
>>> i am receiving other error, this one when i digit *v.in.og*
>>> *D1/5: grass.script.core.start_command(): g.gisenv -n*
>>> *D1/5: G_set_program_name(): g.gisenv*
>>> *D2/5: G_option_to_separator(): key = separator -> sep = '*
>>> *Traceback (most recent call last):*
>>> *  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 310, in
>>> <lambda>*
>>> *    lambda event: self.RunSpecialCmd(event.cmd))*
>>> *  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 623, in
>>> RunSpecialCmd*
>>> *    self.OnImportOgrLayers(event = None, cmd = command)*
>>> *  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 1691, in
>>> OnImportOgrLayers*
>>> *    dlg = GdalImportDialog(parent = self, giface = self._giface, ogr =
>>> True)*
>>> *  File "/usr/lib/grass70/gui/wxpython/gui_core/dialogs.py", line 1878,
>>> in __init__*
>>> *    " ({mightNotWork})".format(mightNotWork=mightNotWork)))*
>>> *UnicodeEncodeError: 'ascii' codec can't encode character u'\xf9' in
>>> position 37: ordinal not in range(128)*
>> What version of grass do you use? You can find it in Help -> About system.
>> I believe this was fixed, see
>> https://trac.osgeo.org/grass/ticket/2720
>> Anna
>>> Il 09/10/2015 10:31 AM, Carmine Massarelli ha scritto:
>>> hi dear,
>>> when i launch the command i.gensigset i receive the error  *'ascii'
>>> codec can't decode byte 0xc3 in position 10: ordinal not in range(128). *This
>>> error could compromise the sigfile?
>>> I use grass-dev on ubuntu 14.04
>>> Thanks
>>> Dr. Nat. Carmine Massarelli, Ph.D. / Technologist
>>> National Research Council - Institute of Water Research
>>> Addr: Via De Blasio, n.5 - 70132 (Ba)
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/8f97c02d/attachment-0001.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/8f97c02d/attachment-0003.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/8f97c02d/attachment-0004.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/8f97c02d/attachment-0005.gif>
