[GRASS-user] GRASS7-dev-error
    Anna Petrášová
    kratochanna at gmail.com
    Thu Sep 10 08:17:28 PDT 2015
On Thu, Sep 10, 2015 at 11:15 AM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Thu, Sep 10, 2015 at 9:35 AM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Thu, Sep 10, 2015 at 9:31 AM, Carmine Massarelli <
>> carmine.massarelli at ba.irsa.cnr.it> wrote:
>>> at the moment i am using 7.0.1 64 bit (not more dev) on ubuntu 14.04.
>>> I saw the tickets, do you suggest me to change the file in the folder
>>> */usr/lib/grass70/gui*?
>>> In addition i have another error with i gengiset (it is unable to
>>> produce sigfile reporting the error *'ascii' codec can't decode byte
>>> 0xc3 in position 10: ordinal not in range(128)*).
>>> Thanks
>> I am little bit confused what are the options on ubuntu, perhaps there is
>> a repository with daily builds? You can change the python files in your
>> current installation or you can compile grass yourself, which is not too
>> difficult.
>> About the other error, I don't know, perhaps you could file a ticket and
>> describe there the exact steps how to reproduce it? And add the debug
>> output.
> I suggested to open a ticket on the other problem with i.gensigset. I
> closed the ticket you opened because it's a duplicate (and solved already).
Oh you just did, sorry.
> Anna
>> Anna
>>> Il 09/10/2015 03:18 PM, Anna Petrášová ha scritto:
>>> On Thu, Sep 10, 2015 at 7:39 AM, Carmine Massarelli <
>>> <carmine.massarelli at ba.irsa.cnr.it>carmine.massarelli at ba.irsa.cnr.it>
>>> wrote:
>>>> Hi all,
>>>> i am receiving other error, this one when i digit *v.in.og*
>>>> *D1/5: grass.script.core.start_command(): g.gisenv -n*
>>>> *D1/5: G_set_program_name(): g.gisenv*
>>>> *D2/5: G_option_to_separator(): key = separator -> sep = '*
>>>> *Traceback (most recent call last):*
>>>> *  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 310, in
>>>> <lambda>*
>>>> *    lambda event: self.RunSpecialCmd(event.cmd))*
>>>> *  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 623, in
>>>> RunSpecialCmd*
>>>> *    self.OnImportOgrLayers(event = None, cmd = command)*
>>>> *  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 1691, in
>>>> OnImportOgrLayers*
>>>> *    dlg = GdalImportDialog(parent = self, giface = self._giface, ogr =
>>>> True)*
>>>> *  File "/usr/lib/grass70/gui/wxpython/gui_core/dialogs.py", line 1878,
>>>> in __init__*
>>>> *    " ({mightNotWork})".format(mightNotWork=mightNotWork)))*
>>>> *UnicodeEncodeError: 'ascii' codec can't encode character u'\xf9' in
>>>> position 37: ordinal not in range(128)*
>>> What version of grass do you use? You can find it in Help -> About
>>> system.
>>> I believe this was fixed, see
>>> https://trac.osgeo.org/grass/ticket/2720
>>> Anna
>>>> Il 09/10/2015 10:31 AM, Carmine Massarelli ha scritto:
>>>> hi dear,
>>>> when i launch the command i.gensigset i receive the error  *'ascii'
>>>> codec can't decode byte 0xc3 in position 10: ordinal not in range(128). *This
>>>> error could compromise the sigfile?
>>>> I use grass-dev on ubuntu 14.04
>>>> Thanks
>>>> Dr. Nat. Carmine Massarelli, Ph.D. / Technologist
>>>> National Research Council - Institute of Water Research
>>>> Addr: Via De Blasio, n.5 - 70132 (Ba)
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/1063cb65/attachment.html>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/1063cb65/attachment.gif>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/1063cb65/attachment-0001.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/1063cb65/attachment-0002.gif>
