[GRASS-user] GRASS7-dev-error
Carmine Massarelli carmine.massarelli at ba.irsa.cnr.it
Thu Sep 10 08:23:18 PDT 2015
ok,
but i tryed to apply in ubuntu 14.04 the file in the two ticket r64372
<https://trac.osgeo.org/grass/changeset/64372> and r64373
<https://trac.osgeo.org/grass/changeset/64373> (for win32) without any
results (the gui did not start).
According to you how is it possible to verify if the problem is in the
GRASS directory?
At the moment I tryed to uninstall and reinstall all grass component or
version without result.
Thanks
Il 09/10/2015 05:15 PM, Anna Petrášová ha scritto:
> On Thu, Sep 10, 2015 at 9:35 AM, Anna Petrášová <kratochanna a gmail.com
> <mailto:kratochanna a gmail.com>> wrote:
>     On Thu, Sep 10, 2015 at 9:31 AM, Carmine Massarelli
>     <carmine.massarelli a ba.irsa.cnr.it
>     <mailto:carmine.massarelli a ba.irsa.cnr.it>> wrote:
>         at the moment i am using 7.0.1 64 bit (not more dev) on ubuntu
>         14.04.
>         I saw the tickets, do you suggest me to change the file in the
>         folder //usr/lib/grass70/gui/?
>         In addition i have another error with i gengiset (it is unable
>         to produce sigfile reporting the error /'ascii' codec can't
>         decode byte 0xc3 in position 10: ordinal not in range(128)/).
>         Thanks
>     I am little bit confused what are the options on ubuntu, perhaps
>     there is a repository with daily builds? You can change the python
>     files in your current installation or you can compile grass
>     yourself, which is not too difficult.
>     About the other error, I don't know, perhaps you could file a
>     ticket and describe there the exact steps how to reproduce it? And
>     add the debug output.
> I suggested to open a ticket on the other problem with i.gensigset. I
> closed the ticket you opened because it's a duplicate (and solved
> already).
> Anna
>     Anna
>         Il 09/10/2015 03:18 PM, Anna Petrášová ha scritto:
>>         On Thu, Sep 10, 2015 at 7:39 AM, Carmine Massarelli
>>             Hi all,
>>             i am receiving other error, this one when i digit /v.in.og/
>>             /D1/5: grass.script.core.start_command(): g.gisenv -n//
>>             //D1/5: G_set_program_name(): g.gisenv//
>>             //D2/5: G_option_to_separator(): key = separator -> sep = '//
>>             //Traceback (most recent call last)://
>>             //  File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py",
>>             line 310, in <lambda>//
>>             //    lambda event: self.RunSpecialCmd(event.cmd))//
>>             line 623, in RunSpecialCmd//
>>             //self.OnImportOgrLayers(event = None, cmd = command)//
>>             line 1691, in OnImportOgrLayers//
>>             //    dlg = GdalImportDialog(parent = self, giface =
>>             self._giface, ogr = True)//
>>             //  File
>>             "/usr/lib/grass70/gui/wxpython/gui_core/dialogs.py", line
>>             1878, in __init__//
>>             ({mightNotWork})".format(mightNotWork=mightNotWork)))//
>>             //UnicodeEncodeError: 'ascii' codec can't encode
>>             character u'\xf9' in position 37: ordinal not in range(128)/
>>         What version of grass do you use? You can find it in Help ->
>>         About system.
>>         I believe this was fixed, see
>>         https://trac.osgeo.org/grass/ticket/2720
>>         Anna
>>             Il 09/10/2015 10:31 AM, Carmine Massarelli ha scritto:
>>>             hi dear,
>>>             when i launch the command i.gensigset i receive the
>>>             error /'ascii' codec can't decode byte 0xc3 in position
>>>             10: ordinal not in range(128). /This error could
>>>             compromise the sigfile?
>>>             I use grass-dev on ubuntu 14.04
>>>             Thanks
>>>             Dr. Nat. Carmine Massarelli, Ph.D. / Technologist
>>>             National Research Council - Institute of Water Research
>>>             Addr: Via De Blasio, n.5 - 70132 (Ba)
>>             _______________________________________________
>>             grass-user mailing list
>>             grass-user a lists.osgeo.org
>>             <mailto:grass-user a lists.osgeo.org>
>>             http://lists.osgeo.org/mailman/listinfo/grass-user
carmine.massarelli a ba.irsa.cnr.it <mailto:carmine.massarelli a ba.irsa.cnr.it>
Mob: +39 339 32 57 311
Tel: +39 080 582 05 06
Un allegato HTML � stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/2d03462c/attachment-0001.html>
Un allegato non testuale � stato rimosso....
Nome:        non disponibile
Tipo:        image/gif
Dimensione:  1097 bytes
Descrizione: non disponibile
URL:         <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/2d03462c/attachment-0004.gif>
Tipo:        image/gif
URL:         <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/2d03462c/attachment-0005.gif>
Tipo:        image/gif
URL:         <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/2d03462c/attachment-0006.gif>
Nome:        spacer.gif
Tipo:        image/gif
URL:         <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/2d03462c/attachment-0007.gif>
