[GRASS-user] GRASS7-dev-error
Carmine Massarelli
carmine.massarelli at ba.irsa.cnr.it
Thu Sep 10 08:51:44 PDT 2015
ok,
i confirm that from terminal it works (different and light form-gui),
not from system-GUI (menu file and then import).
Thanks
Il 09/10/2015 05:30 PM, Anna Petrášová ha scritto:
> On Thu, Sep 10, 2015 at 11:23 AM, Carmine Massarelli
> <carmine.massarelli a ba.irsa.cnr.it
> <mailto:carmine.massarelli a ba.irsa.cnr.it>> wrote:
> ok,
> but i tryed to apply in ubuntu 14.04 the file in the two ticket
> r64372 <https://trac.osgeo.org/grass/changeset/64372> and r64373
> <https://trac.osgeo.org/grass/changeset/64373> (for win32) without
> any results (the gui did not start).
> According to you how is it possible to verify if the problem is in
> the GRASS directory?
> At the moment I tryed to uninstall and reinstall all grass
> component or version without result.
> Thanks
> You can't change the entire file, just the changes. You can also just
> use v.in.ogr from terminal to avoid the graphical dialog which has the
> error.
> Il 09/10/2015 05:15 PM, Anna Petrášová ha scritto:
>> On Thu, Sep 10, 2015 at 9:35 AM, Anna Petrášová
>> <kratochanna a gmail.com <mailto:kratochanna a gmail.com>> wrote:
>> On Thu, Sep 10, 2015 at 9:31 AM, Carmine Massarelli
>> at the moment i am using 7.0.1 64 bit (not more dev) on
>> ubuntu 14.04.
>> I saw the tickets, do you suggest me to change the file
>> in the folder //usr/lib/grass70/gui/?
>> In addition i have another error with i gengiset (it is
>> unable to produce sigfile reporting the error /'ascii'
>> codec can't decode byte 0xc3 in position 10: ordinal not
>> in range(128)/).
>> Thanks
>> I am little bit confused what are the options on ubuntu,
>> perhaps there is a repository with daily builds? You can
>> change the python files in your current installation or you
>> can compile grass yourself, which is not too difficult.
>> About the other error, I don't know, perhaps you could file a
>> ticket and describe there the exact steps how to reproduce
>> it? And add the debug output.
>> I suggested to open a ticket on the other problem with
>> i.gensigset. I closed the ticket you opened because it's a
>> duplicate (and solved already).
>> Anna
>> Anna
>> Il 09/10/2015 03:18 PM, Anna Petrášová ha scritto:
>>> On Thu, Sep 10, 2015 at 7:39 AM, Carmine Massarelli
>>> Hi all,
>>> i am receiving other error, this one when i digit
>>> /v.in.og/
>>> /D1/5: grass.script.core.start_command(): g.gisenv -n//
>>> //D1/5: G_set_program_name(): g.gisenv//
>>> //D2/5: G_option_to_separator(): key = separator ->
>>> sep = '//
>>> //Traceback (most recent call last)://
>>> // File
>>> "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line
>>> 310, in <lambda>//
>>> //lambda event: self.RunSpecialCmd(event.cmd))//
>>> // File
>>> 623, in RunSpecialCmd//
>>> //self.OnImportOgrLayers(event = None, cmd = command)//
>>> // File
>>> 1691, in OnImportOgrLayers//
>>> // dlg = GdalImportDialog(parent = self, giface =
>>> self._giface, ogr = True)//
>>> // File
>>> "/usr/lib/grass70/gui/wxpython/gui_core/dialogs.py",
>>> line 1878, in __init__//
>>> ({mightNotWork})".format(mightNotWork=mightNotWork)))//
>>> //UnicodeEncodeError: 'ascii' codec can't encode
>>> character u'\xf9' in position 37: ordinal not in
>>> range(128)/
>>> What version of grass do you use? You can find it in
>>> Help -> About system.
>>> I believe this was fixed, see
>>> https://trac.osgeo.org/grass/ticket/2720
>>> Anna
>>> Il 09/10/2015 10:31 AM, Carmine Massarelli ha scritto:
>>>> hi dear,
>>>> when i launch the command i.gensigset i receive the
>>>> error /'ascii' codec can't decode byte 0xc3 in
>>>> position 10: ordinal not in range(128). /This error
>>>> could compromise the sigfile?
>>>> I use grass-dev on ubuntu 14.04
>>>> Thanks
>>>> Dr. Nat. Carmine Massarelli, Ph.D. / Technologist
>>>> National Research Council - Institute of Water
>>>> Research
>>>> Addr: Via De Blasio, n.5 - 70132 (Ba)
>>> National Research Council - Institute of Water Research
>>> grass-user mailing list
>>> grass-user a lists.osgeo.org
>>> <mailto:grass-user a lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Mob: +39 339 32 57 311
> Tel: +39 080 582 05 06
carmine.massarelli a ba.irsa.cnr.it <mailto:carmine.massarelli a ba.irsa.cnr.it>
Un allegato HTML � stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/30fd5102/attachment-0001.html>
Un allegato non testuale � stato rimosso....
Nome: non disponibile
Tipo: image/gif
Dimensione: 1097 bytes
Descrizione: non disponibile
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/30fd5102/attachment-0005.gif>
Tipo: image/gif
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/30fd5102/attachment-0006.gif>
Tipo: image/gif
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/30fd5102/attachment-0007.gif>
Tipo: image/gif
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/30fd5102/attachment-0008.gif>
Nome: spacer.gif
Tipo: image/gif
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150910/30fd5102/attachment-0009.gif>
