[GRASS-user] GRASS7-dev-error
Carmine Massarelli carmine.massarelli at ba.irsa.cnr.it
Fri Sep 11 00:32:43 PDT 2015
FYI it needs only to change the /dialogs.py/ file for ubuntu 14.04
(/https://trac.osgeo.org/grass/changeset/64372/).
If you change also the /frame.py/ GRASS does not start correctly.
Now it works.
Thanks
Il 09/10/2015 05:30 PM, Anna Petrášová ha scritto:
> On Thu, Sep 10, 2015 at 11:23 AM, Carmine Massarelli
> <carmine.massarelli a ba.irsa.cnr.it
> <mailto:carmine.massarelli a ba.irsa.cnr.it>> wrote:
>     ok,
>     but i tryed to apply in ubuntu 14.04 the file in the two ticket
>     r64372 <https://trac.osgeo.org/grass/changeset/64372> and r64373
>     <https://trac.osgeo.org/grass/changeset/64373> (for win32) without
>     any results (the gui did not start).
>     According to you how is it possible to verify if the problem is in
>     the GRASS directory?
>     At the moment I tryed to uninstall and reinstall all grass
>     component or version without result.
>     Thanks
>  You can't change the entire file, just the changes. You can also just
> use v.in.ogr from terminal to avoid the graphical dialog which has the
> error.
>     Il 09/10/2015 05:15 PM, Anna Petrášová ha scritto:
>>     On Thu, Sep 10, 2015 at 9:35 AM, Anna Petrášová
>>     <kratochanna a gmail.com <mailto:kratochanna a gmail.com>> wrote:
>>         On Thu, Sep 10, 2015 at 9:31 AM, Carmine Massarelli
>>             at the moment i am using 7.0.1 64 bit (not more dev) on
>>             ubuntu 14.04.
>>             I saw the tickets, do you suggest me to change the file
>>             in the folder //usr/lib/grass70/gui/?
>>             In addition i have another error with i gengiset (it is
>>             unable to produce sigfile reporting the error /'ascii'
>>             codec can't decode byte 0xc3 in position 10: ordinal not
>>             in range(128)/).
>>             Thanks
>>         I am little bit confused what are the options on ubuntu,
>>         perhaps there is a repository with daily builds? You can
>>         change the python files in your current installation or you
>>         can compile grass yourself, which is not too difficult.
>>         About the other error, I don't know, perhaps you could file a
>>         ticket and describe there the exact steps how to reproduce
>>         it? And add the debug output.
>>     I suggested to open a ticket on the other problem with
>>     i.gensigset. I closed the ticket you opened because it's a
>>     duplicate (and solved already).
>>     Anna
>>         Anna
>>             Il 09/10/2015 03:18 PM, Anna Petrášová ha scritto:
>>>             On Thu, Sep 10, 2015 at 7:39 AM, Carmine Massarelli
>>>                 Hi all,
>>>                 i am receiving other error, this one when i digit
>>>                 /v.in.og/
>>>                 /D1/5: grass.script.core.start_command(): g.gisenv -n//
>>>                 //D1/5: G_set_program_name(): g.gisenv//
>>>                 //D2/5: G_option_to_separator(): key = separator ->
>>>                 sep = '//
>>>                 //Traceback (most recent call last)://
>>>                 //  File
>>>                 "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line
>>>                 310, in <lambda>//
>>>                 //lambda event: self.RunSpecialCmd(event.cmd))//
>>>                 //  File
>>>                 623, in RunSpecialCmd//
>>>                 //self.OnImportOgrLayers(event = None, cmd = command)//
>>>                 //  File
>>>                 1691, in OnImportOgrLayers//
>>>                 //    dlg = GdalImportDialog(parent = self, giface =
>>>                 self._giface, ogr = True)//
>>>                 //  File
>>>                 "/usr/lib/grass70/gui/wxpython/gui_core/dialogs.py",
>>>                 line 1878, in __init__//
>>>                 ({mightNotWork})".format(mightNotWork=mightNotWork)))//
>>>                 //UnicodeEncodeError: 'ascii' codec can't encode
>>>                 character u'\xf9' in position 37: ordinal not in
>>>                 range(128)/
>>>             What version of grass do you use? You can find it in
>>>             Help -> About system.
>>>             I believe this was fixed, see
>>>             https://trac.osgeo.org/grass/ticket/2720
>>>             Anna
>>>                 Il 09/10/2015 10:31 AM, Carmine Massarelli ha scritto:
>>>>                 hi dear,
>>>>                 when i launch the command i.gensigset i receive the
>>>>                 error /'ascii' codec can't decode byte 0xc3 in
>>>>                 position 10: ordinal not in range(128). /This error
>>>>                 could compromise the sigfile?
>>>>                 I use grass-dev on ubuntu 14.04
>>>>                 Thanks
>>>>                 Dr. Nat. Carmine Massarelli, Ph.D. / Technologist
>>>>                 National Research Council - Institute of Water
>>>>                 Research
>>>>                 Addr: Via De Blasio, n.5 - 70132 (Ba)
>>>                 National Research Council - Institute of Water Research
>>>                 _______________________________________________
>>>                 grass-user mailing list
>>>                 grass-user a lists.osgeo.org
>>>                 <mailto:grass-user a lists.osgeo.org>
>>>                 http://lists.osgeo.org/mailman/listinfo/grass-user
>     Mob: +39 339 32 57 311
>     Tel: +39 080 582 05 06
carmine.massarelli a ba.irsa.cnr.it <mailto:carmine.massarelli a ba.irsa.cnr.it>
Un allegato HTML � stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150911/f465b21e/attachment-0001.html>
Un allegato non testuale � stato rimosso....
Nome:        non disponibile
Tipo:        image/gif
Dimensione:  1097 bytes
Descrizione: non disponibile
URL:         <http://lists.osgeo.org/pipermail/grass-user/attachments/20150911/f465b21e/attachment-0005.gif>
Tipo:        image/gif
URL:         <http://lists.osgeo.org/pipermail/grass-user/attachments/20150911/f465b21e/attachment-0006.gif>
Tipo:        image/gif
URL:         <http://lists.osgeo.org/pipermail/grass-user/attachments/20150911/f465b21e/attachment-0007.gif>
Tipo:        image/gif
URL:         <http://lists.osgeo.org/pipermail/grass-user/attachments/20150911/f465b21e/attachment-0008.gif>
Nome:        spacer.gif
Tipo:        image/gif
URL:         <http://lists.osgeo.org/pipermail/grass-user/attachments/20150911/f465b21e/attachment-0009.gif>
