[GRASS-user] WARNING: Unable to open raster map...format field in header file invalid
Raphael.Viscarra-Rossel at csiro.au
Fri Sep 11 00:22:09 PDT 2015
Hi Maria, thank you. Yes, the rasters are there - they are listed with
g.listŠ.
Projection is all ok too.
MmmmŠ.
On 11/09/2015 4:27 pm, "Kozlova Maria" <kclo at yandex.ru> wrote:
>Hi, Rafael,
>The first point:
>Typing the comnand:
>d.rast map=xxxx
>you don't load the file. You just display the already imported map from
>existing mapset
>So be sure you files are imported to the current mapset
>You may check this by the command:
>d.list rast (maybe some differences in syntax depending on grass version)
>Second: check the projection in your workspace and imported files
>Hope it helps
>Best regards,
>Maria V. Kozlova
> Information System Lab. (ISysLab)
> State Oceanographic Institute,
> Kropotkinsky per., 6,
> MOSCOW, 119034,
> RUSSIA
> tel. +7 499 246 6448
> fax. +7 499 246 7288
> mailto: kclo at yandex.ru
>11.09.2015, 06:58, "Raphael.Viscarra-Rossel at csiro.au"
><Raphael.Viscarra-Rossel at csiro.au>:
>> Hello,
>> Recently, some grass files that were on my computer were accidentally
>> deleted - I recovered them from backup but it seems that maybe not all.
>> When I open grass and load up a raster with d.rast the map does not
>>appear
>> and I get the following error message:
>> WARNING: Raster map <toc10 at toc@toc>: format field in header file invalid
>> WARNING: Unable to open raster map <toc10 at toc@toc>
>> ERROR: Unable to open raster map <toc10 at toc>
>> Does anyone know what might be missing? And if there is a fix to this?
>> It seems to have happened to all of the rasters that I have in that
>> project!
>> Thank you - Raphael.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
