[GRASS-user] WARNING: Unable to open raster map...format field in header file invalid
Kozlova Maria
kclo at yandex.ru
Thu Sep 10 23:27:31 PDT 2015
Hi, Rafael,
The first point:
Typing the comnand:
d.rast map=xxxx
you don't load the file. You just display the already imported map from existing mapset
So be sure you files are imported to the current mapset
You may check this by the command:
d.list rast (maybe some differences in syntax depending on grass version)
Second: check the projection in your workspace and imported files
Hope it helps
Best regards,
Maria V. Kozlova
Information System Lab. (ISysLab)
State Oceanographic Institute,
Kropotkinsky per., 6,
MOSCOW, 119034,
RUSSIA
tel. +7 499 246 6448
fax. +7 499 246 7288
mailto: kclo at yandex.ru
11.09.2015, 06:58, "Raphael.Viscarra-Rossel at csiro.au" <Raphael.Viscarra-Rossel at csiro.au>:
> Hello,
> Recently, some grass files that were on my computer were accidentally
> deleted - I recovered them from backup but it seems that maybe not all.
> When I open grass and load up a raster with d.rast the map does not appear
> and I get the following error message:
> WARNING: Raster map <toc10 at toc@toc>: format field in header file invalid
> WARNING: Unable to open raster map <toc10 at toc@toc>
> ERROR: Unable to open raster map <toc10 at toc>
> Does anyone know what might be missing? And if there is a fix to this?
> It seems to have happened to all of the rasters that I have in that
> project!
> Thank you - Raphael.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
