[GRASS-user] WARNING: Unable to open raster map...format field in header file invalid
Raphael.Viscarra-Rossel at csiro.au Raphael.Viscarra-Rossel at csiro.au
Fri Sep 11 01:50:02 PDT 2015
Hello Moritz,
Thank you for the suggestions. r.info returns the following
WARNING: can't read range file for [toc10 in toc]
ERROR: Unable to read range file
The frange file I found seems to be there but it is not readable.
I am beginning to thing that whatever I deleted was not recovered and that
I will need to read the data back into grassŠ
What a pain!
Thank you all for your suggestions.
On 11/09/2015 6:00 pm, "Moritz Lennert" <mlennert at club.worldonline.be>
wrote:
>On 11/09/15 09:27, Raphael.Viscarra-Rossel at csiro.au wrote:
>> Hi Markus,
>> YesŠnot sure where the double @ comes from ­ it just displays this in
>> the error messageŠ
>> I looked at the  files in the cellhd folder (which I assume are the
>> header files) and they seem fine:
>> proj:       3
>> zone:       0
>> north:      9:59:50.99856S
>> south:      43:38:32.993713S
>> east:       153:38:23.977878E
>> west:       112:54:41.983744E
>> cols:       48874
>> rows:       40374
>> e-w resol:  0:00:03
>> n-s resol:  0:00:03
>> format:     -1
>> compressed: 1
>This looks fine.
>The error message you cited was:
> >> WARNING: Raster map <toc10 at toc@toc>: format field in header file
>invalid
>but the format field in the header looks ok (-1 => FP map).
>What does r.info tell you on the file ?
>What about launching 'd.mon wx0' + 'd.rast toc10' from the command line ?
>You can also try copying the raster file to a different name with g.copy.
>Another option would be to make your location (or an extract) available
>somewhere so that we can have a look.
>Moritz
