[GRASS-user] WARNING: Unable to open raster map...format field in header file invalid
Moritz Lennert
mlennert at club.worldonline.be
Fri Sep 11 01:00:54 PDT 2015
On 11/09/15 09:27, Raphael.Viscarra-Rossel at csiro.au wrote:
> Hi Markus,
> Yes…not sure where the double @ comes from – it just displays this in
> the error message…
> I looked at the files in the cellhd folder (which I assume are the
> header files) and they seem fine:
> proj: 3
> zone: 0
> north: 9:59:50.99856S
> south: 43:38:32.993713S
> east: 153:38:23.977878E
> west: 112:54:41.983744E
> cols: 48874
> rows: 40374
> e-w resol: 0:00:03
> n-s resol: 0:00:03
> format: -1
> compressed: 1
This looks fine.
The error message you cited was:
>> WARNING: Raster map <toc10 at toc@toc>: format field in header file invalid
but the format field in the header looks ok (-1 => FP map).
What does r.info tell you on the file ?
What about launching 'd.mon wx0' + 'd.rast toc10' from the command line ?
You can also try copying the raster file to a different name with g.copy.
Another option would be to make your location (or an extract) available
somewhere so that we can have a look.
Moritz
