[GRASS-user] d.rast.edit problem grass70 in ubuntu 14.04
Carmine Massarelli carmine.massarelli at ba.irsa.cnr.it
Mon Sep 14 04:14:13 PDT 2015
dear,
I had a lot of problem digiting a raster with d.rast.edit; the only way
to avoid crash and changes losses is insert new values, then enter and
it changes in white (no possible to choose another color or apply two
different changes), then save and exit (if there are a lot of changes
the possibility to crash increase and if i change the view i am not able
to visualise the change not saved).
Have I to move to dev version to use a stable plugin?
Thanks
Dr. Nat. Carmine Massarelli, Ph.D. / Technologist
carmine.massarelli a ba.irsa.cnr.it <mailto:carmine.massarelli a ba.irsa.cnr.it>
National Research Council - Institute of Water Research
Addr: Via De Blasio, n.5 - 70132 (Ba)
Un allegato HTML ? stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150914/37687e34/attachment.html>
Un allegato non testuale ? stato rimosso....
Nome:        spacer.gif
Tipo:        image/gif
Dimensione:  1097 bytes
Descrizione: non disponibile
URL:         <http://lists.osgeo.org/pipermail/grass-user/attachments/20150914/37687e34/attachment.gif>
