[GRASS-user] d.rast.edit problem grass70 in ubuntu 14.04
    Anna Petrášová
    kratochanna at gmail.com
    Mon Sep 14 06:46:12 PDT 2015
On Mon, Sep 14, 2015 at 7:14 AM, Carmine Massarelli <
carmine.massarelli at ba.irsa.cnr.it> wrote:
> dear,
> I had a lot of problem digiting a raster with d.rast.edit; the only way to
> avoid crash and changes losses is insert new values, then enter and it
> changes in white (no possible to choose another color or apply two
> different changes), then save and exit (if there are a lot of changes the
> possibility to crash increase and if i change the view i am not able to
> visualise the change not saved).
> Have I to move to dev version to use a stable plugin?
> Thanks
You can try new raster digitizer in GRASS 7.1, you can switch it in map
display in the dropdown widget where vector digitizing is. You draw
polygons/points/lines, it's not designed for changing individual cells,
although you could do that. It's experimental, let us know what could be
improved. Unfortunately, it doesn't have any documentation yet, but it's
not too complicated.
Anna
> Dr. Nat. Carmine Massarelli, Ph.D. / Technologist
> National Research Council - Institute of Water Research
> Addr: Via De Blasio, n.5 - 70132 (Ba)
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150914/55155d00/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150914/55155d00/attachment.gif>
