[GRASS-user] d.rast.edit problem grass70 in ubuntu 14.04
Carmine Massarelli
carmine.massarelli at ba.irsa.cnr.it
Tue Sep 15 06:52:05 PDT 2015
Thanks a lot...
it works properly: I tried three different changes (without saving every
time) with three different colors and values and moving zoom different
time (changing areas inside and outside the screen).
It never crashed, it never lost the changes.
According to me It has the necessary functions implemented (for my
purposes I could only use this).
Here my workstation specification FYI.
Versione di GRASS: 7.1.svn
GRASS SVN revision: 00000
Build date: 2015-09-15
Build platform: x86_64-pc-linux-gnu
GDAL: 1.11.2
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.8.2
Python: 2.7.6
wxPython: 2.8.12.1
Piattaforma: Linux-3.13.0-58-generic-x86_64-with-Ubuntu-14.04-trusty
Carmine
Il 09/14/2015 03:46 PM, Anna Petrášová ha scritto:
> On Mon, Sep 14, 2015 at 7:14 AM, Carmine Massarelli
> <carmine.massarelli a ba.irsa.cnr.it
> <mailto:carmine.massarelli a ba.irsa.cnr.it>> wrote:
> dear,
> I had a lot of problem digiting a raster with d.rast.edit; the
> only way to avoid crash and changes losses is insert new values,
> then enter and it changes in white (no possible to choose another
> color or apply two different changes), then save and exit (if
> there are a lot of changes the possibility to crash increase and
> if i change the view i am not able to visualise the change not saved).
> Have I to move to dev version to use a stable plugin?
> Thanks
> You can try new raster digitizer in GRASS 7.1, you can switch it in
> map display in the dropdown widget where vector digitizing is. You
> draw polygons/points/lines, it's not designed for changing individual
> cells, although you could do that. It's experimental, let us know what
> could be improved. Unfortunately, it doesn't have any documentation
> yet, but it's not too complicated.
> Anna
> Dr. Nat. Carmine Massarelli, Ph.D. / Technologist
> National Research Council - Institute of Water Research
> Addr: Via De Blasio, n.5 - 70132 (Ba)
> grass-user mailing list
> grass-user a lists.osgeo.org <mailto:grass-user a lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-user
carmine.massarelli a ba.irsa.cnr.it <mailto:carmine.massarelli a ba.irsa.cnr.it>
Un allegato HTML � stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150915/bb82765e/attachment.html>
Un allegato non testuale � stato rimosso....
Nome: non disponibile
Tipo: image/gif
Dimensione: 1097 bytes
Descrizione: non disponibile
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150915/bb82765e/attachment.gif>
Nome: spacer.gif
Tipo: image/gif
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150915/bb82765e/attachment-0001.gif>
