[GRASS-user] Need help in reprojecting raster images
Uttam Kumar
uttamsinha09 at gmail.com
Fri Sep 25 15:59:32 PDT 2015
Thank you all. It worked.
However I noticed that the projected boundary values of N, S, W and E in
GRASS are not same as the values obtained from projecting the same image in
ENVI image processing software and in gdalwarp.
Projection of the scene in Lambert Azimuthal Equal Area is similar (but not
exactly equal) in GRASS and gdal, but in ENVI it is totally different. I
just did the comparison to see if things are similar from different
softwares in case they have to be ported to other platforms.
Any comments is appreciated.
Uttam.
On Wed, Sep 23, 2015 at 12:35 PM, Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hi Uttam,
> you may want to first do v.in.region in your input location, this creates
> a vector with the limits of your input location (set g.region to your
> raster of interest first), then v.proj the output of v.in.region in your
> target location, set region there with the imported vector and just then
> try to reproject the raster image.
> so, steps would be:
> # in input_location
> g.region raster=your_raster
> v.in.region output=vector_region_of_interest
> # in target location
> v.proj location=input_location mapset=input_mapset
> input=vector_region_of_interest output=projected_boundaries
> g.region vector=projected_boundaries
> r.proj location=input_location mapset=input_mapset input=input_raster
> output=output_raster
> You may also wanna check r.import if you use grass7.1 (
> https://grass.osgeo.org/grass71/manuals/r.import.html) or as an add-on in
> grass 7.0 (https://grass.osgeo.org/grass70/manuals/addons/r.import.html).
> You can install it with g.extension r.import
> HTH,
> Vero
> 2015-09-23 15:21 GMT-03:00 Uttam Sinha <uttamsinha09 at gmail.com>:
>> Hi,
>> I tried the way you told. I created a new location in laea without
>> setting the default boundary. Then from this mapset I used
>> r.proj location*=input_location* mapset=*input_mapset* input=*input_raster
>> name* output=
>> *output_raster*
>> I get an error:
>> ERROR: Input raster map is outside current region
>> Any suggestions.
>> Uttam.
>> On Tue, Sep 22, 2015 at 11:59 PM, sajid pareeth <spareeth at gmail.com>
>> wrote:
>>> Hi Uttam
>>> If I understand you correctly you want to reproject a landsat image from
>>> sinusoidal to laea projection!!
>>> You dont have to manually set the bounding box while reprojecting a
>>> raster, as GRASS will take care of it.
>>> First you create a new location and mapset with desired output
>>> projection , which in this case is Lamberts Azimuthal Equal Area.
>>> Then get into this mapset, use the following r.proj command.
>>> name* output=
>>> *output_raster*
>>> More details here: https://grass.osgeo.org/grass70/manuals/r.proj.html
>>> If you then need to set your working area to a particular bounding box,
>>> use g.region
>>> g.region raster=*output_raster*
>>> regards
>>> Sajid
>>> On Tue, Sep 22, 2015 at 11:07 PM, Uttam Sinha <uttamsinha09 at gmail.com>
>>> wrote:
>>>> Hi All,
>>>> I have a set of Landsat images in Sinusoidal Projection, WGS84 Datum. I
>>>> know the north, south, east and west extent of the boundary of the image.
>>>> I want to reproject the image to Lamberts Azimuthal Equal Area, WGS84
>>>> Datum. I do not know what will be the coordinates of the north, south, east
>>>> and west bounds in this projection.
>>>> 1.) How do I convert upper left coordinates and bottom right
>>>> coordinates of Sinusoidal Projection to Lamberts Azimuthal Equal Area to
>>>> create a new destination Location?
>>>> 2.) How do I reproject the images from Sinusoidal to Lamberts without
>>>> georeferencing the image at source location (in sinusoidal projection)
>>>> Appreciate any reply.
>>>> Uttam.
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150925/01544342/attachment.html>
