[GRASS-user] v.in.ogr: encoding problem with shapefile DBF file
RichardCooper richtcooper at hotmail.com
Wed Sep 30 23:34:47 PDT 2015
I'm getting an error on attempting to import a shapefile with a DBF file
containing Thai characters (sample below) using v.in.ogr. I've also
attempted to set encoding as per
https://grass.osgeo.org/grass70/manuals/v.in.ogr.html
The file is utf-8 and the headers do not contain Thai characters.
I can open the file in QGIS and view Thai characters in its attribute table,
but in GRASS, only the attribute column headers are imported.
I'd be grateful for any suggestions.
Cheers,
Richard
Error from GRASS command console:
v.in.ogr input= ../Bridge.shp layer=Bridge output=Bridge --overwrite
encoding=utf8
Check if OGR layer <Bridge> contains polygons...
WARNING: Vector map <Bridge> already exists and will be overwritten
Importing 1189 features (OGR layer <Bridge>)...
DBMI-PostgreSQL driver error:
Unable to execute:
insert into public.Bridge values ( 1, '', '', '',
0.00000000000, 0.00000000000, 0.00000000000,
'ถนนประชาร่วมใจ', '6', 6, 0, 0,
0.00000000000, 6.00000000000, '', '', 0, 0, 0, 0, 0, 0, 0,
0, '', 0, 0, '', '', '', '', '', 0.00000000000, '', '', '',
'', '', '', 0.00000000000, 0.00000000000, 0.00000000000, '',
'', '', '', 41, 0.00000000000, '', 0.00000000000, 0.000000 )
ERROR:  invalid input syntax for type date: ""
LINE 1: ...มใจ', '6', 6, 0, 0, 0.00000000000,
6.00000000000, '', '', 0,...
Unable to execute:
ERROR: Cannot insert new row: insert into public.Bridge values ( 1, '', '',
'', 0.00000000000, 0.00000000000, 0.00000000000, 'ถนนประชาร่วมใจ', '6', 6,
0, 0, 0.00000000000, 6.00000000000, '', '', 0, 0, 0, 0, 0, 0, 0, 0, '', 0,
0, '', '', '', '', '', 0.00000000000, '', '', '', '', '', '', 0.00000000000,
0.00000000000, 0.00000000000, '', '', '', '', 41, 0.00000000000, '',
(Thu Oct  1 13:30:44 2015) Command finished (0 sec)
System info:
GRASS version: 7.0.1svn
GRASS SVN Revision: 65041
Build Date: 2015-04-10
Build Platform: x86_64-unknown-linux-gnu
GDAL/OGR: 1.11.2
PROJ.4: 4.9.0
GEOS: 3.4.2
SQLite: 3.8.2
Python: 2.7.6
wxPython: 2.8.12.1
Platform: Linux-3.13.0-37-generic-x86_64-with-LinuxMint-17.1-rebecca
Top 8 lines of problem column in DBF file:
NameT,C,250
ถนนประชาร่วมใจ
ทางหลวงชนบท สค. 4011
ถนนวัดกระซ้าขาว
ซอยพระราม 2 (ซอย 4)
ถนนเอนกอุดมผล
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-in-ogr-encoding-problem-with-shapefile-DBF-file-tp5227195.html
Sent from the Grass - Users mailing list archive at Nabble.com.
