[GRASS-user] v.net vector orientation when creating a stream network with gauges
Moritz Lennert mlennert at club.worldonline.be
Sat Apr 9 06:41:44 PDT 2016
On 09/04/16 12:32, Bartolomei.Chris wrote:
> Hi Markus, I was able to get back to this issue and tried what you
> had suggested with creating the new layer 3 and re-categorizing the
> stream after v.net op=connect ... but to no avail. I even tried
> setting the forward and backward costs of the little vectors added by
> v.net to a positive value (1)
In grass7 v.net should not add little lines when used with the -s flag.
Which version of GRASS are you using ? If grass7x then this would be a
bug and you should file a bug report concerning v.net with a
reproductible example of the issue.
Moritz
