[GRASS-user] v.net vector orientation when creating a stream network with gauges
Bartolomei.Chris Bartolomei.Chris at ensco.com
Mon Apr 11 09:04:06 PDT 2016
Good morning Markus,
I'm using GRASS 6.4.4
I may be stuck using it as the client is running this version instead of GRASS 7 (legacy scripts)
Do you think running v.net -a would help? It may be that there are no nodes at the junction of the little vectors that were added added with the v.net op=connect step (???)
I have the stream vector map, points, and script in about a 1.3Mb zip file if you would like to see them.
Thanks again for the help!
Chris
Chris Bartolomei P.E.
Engineer/Scientist
ENSCO, Inc.
4849 North Wickham Road
Melbourne, FL 32940 (official office)
5038 Park Rim Drive
San Diego, CA 92117 (home office)
(858) 581-3005
bartolomei.chris at ensco.com
________________________________________
From: Moritz Lennert [mlennert at club.worldonline.be]
Sent: Saturday, April 09, 2016 6:41 AM
To: Bartolomei.Chris; Markus Metz
Cc: grass-user
Subject: Re: [GRASS-user] v.net vector orientation when creating a stream network with gauges
On 09/04/16 12:32, Bartolomei.Chris wrote:
> Hi Markus, I was able to get back to this issue and tried what you
> had suggested with creating the new layer 3 and re-categorizing the
> stream after v.net op=connect ... but to no avail. I even tried
> setting the forward and backward costs of the little vectors added by
> v.net to a positive value (1)
In grass7 v.net should not add little lines when used with the -s flag.
Which version of GRASS are you using ? If grass7x then this would be a
bug and you should file a bug report concerning v.net with a
reproductible example of the issue.
Moritz
The information contained in this email message is intended only for the use of the individual(s) to whom it is addressed and may contain information that is privileged and sensitive. If you are not the intended recipient, or otherwise have received this communication in error, please notify the sender immediately by email at the above referenced address and note that any further dissemination, distribution or copying of this communication is strictly prohibited.
The U.S. Export Control Laws regulate the export and re-export of technology originating in the United States. This includes the electronic transmission of information and software to foreign countries and to certain foreign nationals. Recipient agrees to abide by these laws and their regulations -- including the U.S. Department of Commerce Export Administration Regulations and the U.S. Department of State International Traffic in Arms Regulations -- and not to transfer, by electronic transmission or otherwise, any content derived from this email to either a foreign national or a foreign destination in violation of such laws.
