[GRASS-user] temporal dataset : register maps from other mapsets
Veronica Andreo veroandreo at gmail.com
Sun Apr 17 03:40:18 PDT 2016
Ops, dismiss previous email... Eheh! :P
Thanks for the explanation and hint, Sören!
El abr 17, 2016 7:32 AM, "Veronica Andreo" <veroandreo at gmail.com> escribió:
Hi Martin,
What if you try running t.connect -d (set from default) in PERMANENT first?
The error says there's no temporal database connection defined. Maybe that
works.
Cheers,
Vero
El abr 17, 2016 7:08 AM, "Martin Landa" <landa.martin at gmail.com> escribió:
> Hi,
> I wonder why it's not possible to register in temporal dataset maps
> from other mapsets?
> Module `t.register` fails to register maps from PERMANENT mapset in my
> current mapset (`landa):
> t.create output=modis title="MODIS 2002" desc="Ukazkovy casoprostorovy
> dataset MODIS"
> g.list type=raster mapset=PERMANENT sep='newline' out=maps.txt -m
> t.register input=modis file=maps.txt sep='newline'
> ERROR: Unable to execute sql statement. There is no temporal database
> connection defined for mapset <PERMANENT>
> So I am able to register only maps from the current mapset. Why? Ma
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160417/a7a327ba/attachment.html>
