[GRASS-user] temporal dataset : register maps from other mapsets
Sören Gebbert
soerengebbert at googlemail.com
Sun Apr 17 03:56:58 PDT 2016
Hi Vero,
I have send my mail just a second after i recieved your mail ... .
However, i would like to add that a second temporal GIS environmental
variable exists, that disables the write of map layer metadata:
TGIS_DISABLE_TIMESTAMP_WRITE
Set it with:
g.gisenv set="TGIS_DISABLE_TIMESTAMP_WRITE=True
This will avoid that time stamps are written as text files in the map layer
specific metadata directory by the temporal framework. The drawback is that
modules written in C are not able to determine if the map layer has a
timestamp using the C-API. The benefit is that map layer specific data in
other mapsets are not modified if the space time dataset are modified.
Best regards
Soeren
2016-04-17 12:40 GMT+02:00 Veronica Andreo <veroandreo at gmail.com>:
> Ops, dismiss previous email... Eheh! :P
> Thanks for the explanation and hint, Sören!
> El abr 17, 2016 7:32 AM, "Veronica Andreo" <veroandreo at gmail.com>
> escribió:
> Hi Martin,
> What if you try running t.connect -d (set from default) in PERMANENT
> first? The error says there's no temporal database connection defined.
> Maybe that works.
> Cheers,
> Vero
> El abr 17, 2016 7:08 AM, "Martin Landa" <landa.martin at gmail.com> escribió:
>> Hi,
>> I wonder why it's not possible to register in temporal dataset maps
>> from other mapsets?
>> Module `t.register` fails to register maps from PERMANENT mapset in my
>> current mapset (`landa):
>> t.create output=modis title="MODIS 2002" desc="Ukazkovy casoprostorovy
>> dataset MODIS"
>> g.list type=raster mapset=PERMANENT sep='newline' out=maps.txt -m
>> t.register input=modis file=maps.txt sep='newline'
>> ERROR: Unable to execute sql statement. There is no temporal database
>> connection defined for mapset <PERMANENT>
>> So I am able to register only maps from the current mapset. Why? Ma
>> Martin Landa
>> http://geo.fsv.cvut.cz/gwiki/Landa
>> http://gismentors.cz/mentors/landa
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160417/3d7fb41a/attachment.html>
