[GRASS-user] simple way to get Easting and Northing coordinates of stream outlet directly from r.watershed?
Helmut Kudrnovsky hellik at web.de
Tue Apr 26 06:16:52 PDT 2016
jamaas wrote
> I'm using GRASS 7.0.3 (text) on Ubuntu Linux, and running it either from
> a bash shell script or from an R file.
> I've worked out a workflow that does what I want, but it is very long
> and convoluted, so I'm wondering if there is a simple way to extract the
> Easting and Northing coordinates of the lowest point on the stream
> network, such that I can then use them as inputs for r.water.outlet?
> Here is my workflow, realise it is long
>  1. run r.watershed to get drainage, streams, and basin
>  2. run r.stream.order to calculate strahler order and get strahler
>     raster map
>  3. use r.stats and some bash code to extract highest strahler number
>     from the strahler map
>  4. use r.mapcalc .... not sure why, inherited this bit from someone!
>  5. use r.stats to get data from stream dem into a text file
>  6. use some bash and awk code to extract the Easting and Northing
>     values of the lowest point in the text file created from the stream
> dem
>  7. use r.water.outlet to create new drainage map for the basin
>  8. use r.lfp  to calculate longest flow path, also uses the Northing
>     and Easting values of the outflow point
> So I guess what I'm looking for is a simpler way to get the Northing and
> Easting values of the lowest point, directly from r.watershed or
> something analogous.
> All suggestions most welcome. Thanks
have a look at
https://grasswiki.osgeo.org/wiki/R.basin#Preparation_for_multiple_basins.27_analysis
maybe for some inspirations.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/simple-way-to-get-Easting-and-Northing-coordinates-of-stream-outlet-directly-from-r-watershed-tp5262970p5262976.html
Sent from the Grass - Users mailing list archive at Nabble.com.
