[GRASS-user] simple way to get Easting and Northing coordinates of stream outlet directly from r.watershed?
Jim Maas j.maas at uea.ac.uk
Tue Apr 26 23:37:52 PDT 2016
Thanks Stefan,
I guess I should have mentioned, the whole point of all this work is to
get the appropriate input data, including the topidx map required to run
topmodel for a two year period, on very small catchments (25km^2 ).  I
can run either the GRASS or R version of topmodel, but it appears that
the R version is better equipped to do sensitivity analysis, i.e. pass
it a parameters file with multiple lines of parameters, through which it
will iterate and do the sensitivity analysis.  I'm assuming this doesn't
change your advice?
Thanks
J
On 26/04/16 22:10, Blumentrath, Stefan wrote:
> Hi Jim,
> If I understood you final objective correctly, I would say 2: r.stream.basins, will replace most of your workflow...
> With the stream_rast option, r.stream.basisns produces basins using raster input maps with "multiple outlets".
> You can feed this option either with a raster map of your whole stream (which naturally covers the outlet) or even specify categories of the streams  you want to get the basisns for. Citing from the manual:
> To delineate one or more particular basins defined by given streams, add simply stream categories:
> r.stream.basins -lc direction=direction stream_rast=streams cats=2,7,184 basins=bas_basin
> See also: https://grasswiki.osgeo.org/wiki/R.stream.*_modules and of course the related scientific paper: http://www.sciencedirect.com/science/article/pii/S0098300411000975
> Hope that helps.
> Cheers
> Stefan
> -----Original Message-----
> From: Jim Maas [mailto:j.maas at uea.ac.uk]
> Sent: 26. april 2016 15:44
> To: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>; grass-user at lists.osgeo.org
> Subject: Re: [GRASS-user] simple way to get Easting and Northing coordinates of stream outlet directly from r.watershed?
> Hi Stefan,
> Thanks for this.  I've had a look but not tried it yet.  Just for me to clarify, are you suggesting that:
>   1. r.stream.basins will somehow produce and output the Easting and
>      Northing values of the overall outlet?
>   2. r.stream.basins, will replace most of this workflow and thus the
>      Eastings and Northings will not be required explicitly?
> In the case of 1, I can't quite see how it will output these values?
> Thanks a bunch,
> J
> On 26/04/16 14:02, Blumentrath, Stefan wrote:
>> Hi,
>> Did you consider using:
>> https://grass.osgeo.org/grass70/manuals/addons/r.stream.basins.html
>> Cheers
>> Stefan
>> From: grass-user [mailto:grass-user-bounces at lists.osgeo.org] On Behalf
>> Of Jim Maas
>> Sent: 26. april 2016 14:28
>> To: grass-user at lists.osgeo.org
>> Subject: [GRASS-user] simple way to get Easting and Northing coordinates of stream outlet directly from r.watershed?
>> I'm using GRASS 7.0.3 (text) on Ubuntu Linux, and running it either from a bash shell script or from an R file.
>> I've worked out a workflow that does what I want, but it is very long and convoluted, so I'm wondering if there is a simple way to extract the Easting and Northing coordinates of the lowest point on the stream network, such that I can then use them as inputs for r.water.outlet?
>> Here is my workflow, realise it is long
>>    1. run r.watershed to get drainage, streams, and basin  2. run r.stream.order to calculate strahler order and get strahler
>>       raster map
>>    3. use r.stats and some bash code to extract highest strahler number
>>       from the strahler map
>>    4. use r.mapcalc .... not sure why, inherited this bit from someone!
>>    5. use r.stats to get data from stream dem into a text file  6. use some bash and awk code to extract the Easting and Northing
>>       values of the lowest point in the text file created from the stream dem  7. use r.water.outlet to create new drainage map for the basin  8. use r.lfp  to calculate longest flow path, also uses the Northing
>>       and Easting values of the outflow point
>> So I guess what I'm looking for is a simpler way to get the Northing and Easting values of the lowest point, directly from r.watershed or something analogous.
>> All suggestions most welcome. Thanks
>> J
>> Dr. Jim Maas
>> University of East Anglia
>> grass-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Dr. Jim Maas
Dr. Jim Maas
Mathematical Modelling in
Epidemiology of Infectious Disease
Rm 2.13 MED
Norwich Medical School
Norwich Research Park,
NR4 7TJ  U.K.
E: j.maas at uea.ac.uk
