[GRASS-user] Copy an existing location
Bartolomei.Chris Bartolomei.Chris at ensco.com
Thu Apr 28 00:10:14 PDT 2016
I would create a new mapset (in the same "location") then use g.copy (or the gui) to copy the rasters from PERMANENT to the new mapset.
You can then pack the mapset directory (folder) (".tar" or ".gz" or ".zip") and send it to the other user - they should have the same "location" you do, have them create a new mapset the same as the one you created, then they can unpack (extract) the folder contents into the mapset location overwriting the defaults.  That should work...
Chris Bartolomei P.E.
Engineer/Scientist
ENSCO, Inc.
bartolomei.chris at ensco.com
________________________________________
From: grass-user [grass-user-bounces at lists.osgeo.org] On Behalf Of Janet Choate [jsc.eco at gmail.com]
Sent: Wednesday, April 27, 2016 7:00 PM
To: grass list
Subject: [GRASS-user] Copy an existing location
Hello GRASS community,
Does anyone have advice on duplicating an existing GRASS location with only certain rasters maps?
For example, I have an existing GRASS location with a PERMANENT mapset that contains 100 maps. I want to create a copy of this existing location (with it's current projection) to a new location, which will only contain 10 of the rater maps from the existing location.
I want to be able to transfer a new 'cleaned-up' version of my GRASS location to another user.
thank you,
Janet
The information contained in this email message is intended only for the use of the individual(s) to whom it is addressed and may contain information that is privileged and sensitive. If you are not the intended recipient, or otherwise have received this communication in error, please notify the sender immediately by email at the above referenced address and note that any further dissemination, distribution or copying of this communication is strictly prohibited.
The U.S. Export Control Laws regulate the export and re-export of technology originating in the United States. This includes the electronic transmission of information and software to foreign countries and to certain foreign nationals. Recipient agrees to abide by these laws and their regulations -- including the U.S. Department of Commerce Export Administration Regulations and the U.S. Department of State International Traffic in Arms Regulations -- and not to transfer, by electronic transmission or otherwise, any content derived from this email to either a foreign national or a foreign destination in violation of such laws.
