[GRASS-user] Copy an existing location
Paulo van Breugel p.vanbreugel at gmail.com
Thu Apr 28 00:54:31 PDT 2016
There is also the r.pack function. But what I would probably do is to copy
the whole location folder, delete the layers you don't want to include, and
then zip / 7zip the whole folder (which is lossless) or any other suitable
format.
On Thu, Apr 28, 2016 at 9:44 AM, Bartolomei.Chris <
Bartolomei.Chris at ensco.com> wrote:
> Hi Janet ... I was just thinking about the suggestion I sent ... you may
> be better off exporting the rasters and then having the user import them
> into a like-named mapset with the projection set to what the original
> rasters are in (and set the region and resolution correctly prior to
> import). The reason I say this is the file compression I suggested may
> cause some data loss ... look into lossless data compression algorithms and
> you'll see what I'm talking about.
> It may be irrelevent, but I'm not 100% sure... something to be aware of
> though.
> Chris Bartolomei P.E.
> Engineer/Scientist
> ENSCO, Inc.
> bartolomei.chris at ensco.com
> ________________________________________
> From: grass-user [grass-user-bounces at lists.osgeo.org] On Behalf Of Janet
> Choate [jsc.eco at gmail.com]
> Sent: Wednesday, April 27, 2016 7:00 PM
> To: grass list
> Subject: [GRASS-user] Copy an existing location
> Hello GRASS community,
> Does anyone have advice on duplicating an existing GRASS location with
> only certain rasters maps?
> For example, I have an existing GRASS location with a PERMANENT mapset
> that contains 100 maps. I want to create a copy of this existing location
> (with it's current projection) to a new location, which will only contain
> 10 of the rater maps from the existing location.
> I want to be able to transfer a new 'cleaned-up' version of my GRASS
> location to another user.
> thank you,
> Janet
> The information contained in this email message is intended only for the
> use of the individual(s) to whom it is addressed and may contain
> information that is privileged and sensitive. If you are not the intended
> recipient, or otherwise have received this communication in error, please
> notify the sender immediately by email at the above referenced address and
> note that any further dissemination, distribution or copying of this
> communication is strictly prohibited.
> The U.S. Export Control Laws regulate the export and re-export of
> technology originating in the United States. This includes the electronic
> transmission of information and software to foreign countries and to
> certain foreign nationals. Recipient agrees to abide by these laws and
> their regulations -- including the U.S. Department of Commerce Export
> Administration Regulations and the U.S. Department of State International
> Traffic in Arms Regulations -- and not to transfer, by electronic
> transmission or otherwise, any content derived from this email to either a
> foreign national or a foreign destination in violation of such laws.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160428/c7c60d55/attachment-0001.html>
