[GRASS-user] why is v.build.all (and many others) a windows batch file and not an executable?
Bartolomei.Chris
Bartolomei.Chris at ensco.com
Fri Apr 29 22:46:58 PDT 2016
Good evening and happy weekend!
I am (still) upgrading from 6.4.4 to 7.0.3 and I discovered that the vector topography of all my data is not upwards compatible so per the instructions at https://grasswiki.osgeo.org/wiki/Convert_all_GRASS_6_vector_maps_to_GRASS_7 I am (trying) to us v.build.all to update the topography. I had installed GRASS with MSYS from OSGEO4W but that goodness uses the unix-like msys shell as the command console - which for what I need is perfect ... I can copy/paste commands to test as I write shell scripts to do GIS magic. BUT ... go ahead and try to run v.build.all ... and nope - it isn't going to let you. Ends up v.build.all (and many other modules) are Windows Batch files !! the msys command console won't run the GRASS modules that are Windows Batch files. I was able to work around this a little issue by also installing just the regular GRASS 7.0.3 (they install in different directories) and run the v.build.all from the Windows cmd console (it is the standard command console that runs with "normal" 7.0.3 (not from OSGEO4W) but which won't run any of the code I put into a shell script because, well, it's unix shell not DOS - hence the need for msys)... I was going to drop a note to the OSGEO4W project about the issue but the same thing is part of the current (non-OSGEO4W) package ... look in \Program Files\GRASS GIS 7.0.3\bin\ and you'll see many executables (compiled python scripts I assume) and quite a few Windows Batch files.... why is this? Should they not all be compiled executables ??
I don't understand this and it makes it really hard to create shell scripts to run the modules...
Thanks,
Chris
Chris Bartolomei P.E.
Engineer/Scientist
ENSCO, Inc.
bartolomei.chris at ensco.com
The information contained in this email message is intended only for the use of the individual(s) to whom it is addressed and may contain information that is privileged and sensitive. If you are not the intended recipient, or otherwise have received this communication in error, please notify the sender immediately by email at the above referenced address and note that any further dissemination, distribution or copying of this communication is strictly prohibited.
The U.S. Export Control Laws regulate the export and re-export of technology originating in the United States. This includes the electronic transmission of information and software to foreign countries and to certain foreign nationals. Recipient agrees to abide by these laws and their regulations -- including the U.S. Department of Commerce Export Administration Regulations and the U.S. Department of State International Traffic in Arms Regulations -- and not to transfer, by electronic transmission or otherwise, any content derived from this email to either a foreign national or a foreign destination in violation of such laws.
