[GRASS-user] PostgreSQL not in v.out.ogr format options
Moritz Lennert mlennert at club.worldonline.be
Sat Apr 30 05:55:05 PDT 2016
[Please keep discussions on the list]
On 29/04/16 19:35, Peter Tittmann wrote:
> Thx  for your reply!
>    -> "PostgreSQL" (read/write)
And
v.in.ogr -f | grep PostgreSQL
If that doesn't show success, then it would seem to me that there might
be an issue in your installation with GRASS not picking up the correct
ogr libraries.
On what OS are you ?
Moritz
>> On Apr 29, 2016, at 10:27 AM, Moritz Lennert
>> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
>> wrote:
>> On 29/04/16 18:00, Peter Tittmann wrote:
>>> All,
>>> Using GRASS7. I would like to write to postgis from a GRASS vector file,
>>> and would like to be able to append to a table as opposed to create new.
>>> I see that the `-a` flag is not implemented yet in v.out.postgis so I
>>> turned to v.out.ogr. Despite having a fully functional GDAL with the OGR
>>> PostgreSQL driver installed and functional, when I pass the following
>>> command:
>>> `v.out.ogr -a -m --verbose input=t_lands type=area
>>> output="PG:dbname=cf_tribal" output_layer=foo format=PostgreSQL`
>>>  the response is:
>>> `ERROR: Value <PostgreSQL> out of range for parameter <format>
>>> Legal range:
>>> BNA,CSV,CartoDB,Cloudant,CouchDB,DGN,DXF,ESRI_Shapefile,ElasticSearch,GFT,GME,GML,GPKG,GPSBabel,GPSTrackMaker,GPX,GeoJSON,GeoRSS,Geoconcept,JML,KML,MapInfo_File,Memory,ODS,OGR_GMT,PCIDSK,PDF,PGDUMP,S57,SQLite,Selafin,TIGER,WAsP,XLSX`
>> What does
>> ogrinfo --formats | grep PostgreSQL
>> give you ?
>> Moritz
