[GRASS-user] PostgreSQL not in v.out.ogr format options
Moritz Lennert
mlennert at club.worldonline.be
Fri Apr 29 10:27:42 PDT 2016
On 29/04/16 18:00, Peter Tittmann wrote:
> All,
> Using GRASS7. I would like to write to postgis from a GRASS vector file,
> and would like to be able to append to a table as opposed to create new.
> I see that the `-a` flag is not implemented yet in v.out.postgis so I
> turned to v.out.ogr. Despite having a fully functional GDAL with the OGR
> PostgreSQL driver installed and functional, when I pass the following
> command:
> `v.out.ogr -a -m --verbose input=t_lands type=area
> output="PG:dbname=cf_tribal" output_layer=foo format=PostgreSQL`
> the response is:
> `ERROR: Value <PostgreSQL> out of range for parameter <format>
> Legal range:
> BNA,CSV,CartoDB,Cloudant,CouchDB,DGN,DXF,ESRI_Shapefile,ElasticSearch,GFT,GME,GML,GPKG,GPSBabel,GPSTrackMaker,GPX,GeoJSON,GeoRSS,Geoconcept,JML,KML,MapInfo_File,Memory,ODS,OGR_GMT,PCIDSK,PDF,PGDUMP,S57,SQLite,Selafin,TIGER,WAsP,XLSX`
What does
ogrinfo --formats | grep PostgreSQL
give you ?
Moritz
