[GRASS-user] where is MSYS in GRASS 7?
Jürgen E. Fischer jef at norbit.de
Sat Apr 30 10:12:35 PDT 2016
Hi Martin,
On Sat, 30. Apr 2016 at 13:49:20 +0200, Martin Landa wrote:
> AFAIU this must be defined in the GRASS env file (so the file which is
> loaded when GRASS is started - by bat file). Ma
grass70.bat calls o4w_env.bat which in turn calls all batch files in etc/ini
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160430/ff94a5dc/attachment-0001.sig>
