[GRASS-user] where is MSYS in GRASS 7?
Bartolomei.Chris Bartolomei.Chris at ensco.com
Fri Apr 29 09:46:13 PDT 2016
Whew! ... thank you - that worked.
Just a couple notes: the C:\OSGeo4W/apps/grassX/etc/env.bat file did not have the GRASS_SH line in it so I just added it as you typed out and it works.
Also for anyone else trying this:
When installing GRASS from OSGEO4W, even if you select 7.0.4RC1 you still get 7.0.3 ... and if you install using the Express Desktop Install, you will need to go back and run the installer again, then select Advanced Installation and then in the Select Packages window, select msys and install that.
Not difficult nor time-consuming, but if you don't there's no msys on your system.
Thanks again!
Chris
Chris Bartolomei P.E.
Engineer/Scientist
ENSCO, Inc.
bartolomei.chris at ensco.com
________________________________________
Sent: Friday, April 29, 2016 12:59 AM
To: Bartolomei.Chris
Cc: Helmut Kudrnovsky; grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] where is MSYS in GRASS 7?
2016-04-29 9:52 GMT+02:00 Bartolomei.Chris <Bartolomei.Chris at ensco.com>:
> Oh no .... that is really really bad (for me) ... does this mean all of my shell (sh) scripts have to be rewritten in python?
> That may be a ridiculous amount of work ... So much for "upgrading".
> I hope 6.4.4 is going to be around for a long time then.  :(
it's easy to switch to msys. Install grass and msys from OSGeo4W. Edit
C:\OSGeo4W/apps/grassX/etc/env.bat.
REM set GRASS_SH=%OSGEO4W_ROOT%\apps\msys\bin\sh.exe
Ma
Martin Landa
https://urldefense.proofpoint.com/v2/url?u=http-3A__geo.fsv.cvut.cz_gwiki_Landa&d=CwIBaQ&c=DsZY2bea7iNIzyp-7sZ0t0F2UfNQZUfZhEPCv_2wBI0&r=O31ltou6ygJL2Y01kQyNJJD2kiILIsbyz2V0Hn4lFUY&m=59HfvpOtRzPLNaYoyY2ldVu4GUDH7aSFxjWA940iQAo&s=n54WV3gS2tfvNGL0j02xv7Bv1U6LoPxNfagkq4J_VRc&e=
https://urldefense.proofpoint.com/v2/url?u=http-3A__gismentors.cz_mentors_landa&d=CwIBaQ&c=DsZY2bea7iNIzyp-7sZ0t0F2UfNQZUfZhEPCv_2wBI0&r=O31ltou6ygJL2Y01kQyNJJD2kiILIsbyz2V0Hn4lFUY&m=59HfvpOtRzPLNaYoyY2ldVu4GUDH7aSFxjWA940iQAo&s=R_sWVv5oRnPNIQma4384DEO9AxguRVmZ3EexvHaARDo&e=
The information contained in this email message is intended only for the use of the individual(s) to whom it is addressed and may contain information that is privileged and sensitive. If you are not the intended recipient, or otherwise have received this communication in error, please notify the sender immediately by email at the above referenced address and note that any further dissemination, distribution or copying of this communication is strictly prohibited.
The U.S. Export Control Laws regulate the export and re-export of technology originating in the United States. This includes the electronic transmission of information and software to foreign countries and to certain foreign nationals. Recipient agrees to abide by these laws and their regulations -- including the U.S. Department of Commerce Export Administration Regulations and the U.S. Department of State International Traffic in Arms Regulations -- and not to transfer, by electronic transmission or otherwise, any content derived from this email to either a foreign national or a foreign destination in violation of such laws.
