[GRASS-user] where is MSYS in GRASS 7?
Martin Landa
landa.martin at gmail.com
Sat Apr 30 04:47:54 PDT 2016
2016-04-29 18:46 GMT+02:00 Bartolomei.Chris <Bartolomei.Chris at ensco.com>:
> Just a couple notes: the C:\OSGeo4W/apps/grassX/etc/env.bat file did not have the GRASS_SH line in it so I just added it as you typed out and it works.
right, I re-added this line recently, will be included in GRASS 7.0.4.
> When installing GRASS from OSGEO4W, even if you select 7.0.4RC1 you still get 7.0.3 ... and if you install using the Express Desktop Install, you will need to go back and run the installer again, then select Advanced Installation and then in the Select Packages window, select msys and install that.
To install 7.0.4RC1 you need to choose Exp option (only available in
Advanced installation). Express Desktop option should offer only GRASS
7.0.3.
Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
