[GRASS-user] Error when using r.viewshed.cva
Adam Hoffritz
adamhoffritz89 at gmail.com
Wed Aug 10 07:32:54 PDT 2016
Good day,
When trying to run r.viewshed.cva i keep getting this error (see below)
(This is the entire report, you can see the inputs).
Am I missing something obvious? I do not use Grass often, work mostly on
ArcGis but I am moving towards Grass.
r.viewshed.cva input=Clip_haedarlikan at RHIVidsyni
vector=Grass_vidsyniPrufa at RHIVidsyni output=prufa
Note that the routine is constrained to points in the current geographic
region.
Memory manager registering memory in MM_IGNORE_MEMORY_EXCEEDED mode.
WARNING: Illegal filename <vshed_0
>. Character <
> not allowed.
ERROR: AMI_STREAM::write_item failed.
C:\Users\Adam\Desktop\LUK-GIS\GRASS/RHIvidsyni/RHIVidsyni/.t
mp/unknown/14496.0/STREAM_baaaaX: No space left on device
File "C:\Users\Adam\AppData\Roaming\GRASS7\addons/scripts/
r.viewshed.cva.py", line 174, in <module>
main()
r.viewshed.cva.py", line 159, in main
grass.run_command("r.viewshed", quiet = True,
overwrite=grass.overwrite(), flags=flagstring, input=elev,
output=tempry, coordinates=site[0] + "," + site[1],
**viewshed_options)
File "C:\Program Files\GRASS GIS
7.0.4\etc\python\grass\script\core.py", line 395, in
run_command
return handle_errors(returncode, returncode, args,
kwargs)
7.0.4\etc\python\grass\script\core.py", line 313, in
handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None
['r.viewshed', '--q', 'observer_elevation=1.75',
'input=Clip_haedarlikan at RHIVidsyni',
'refraction_coeff=0.14286',
'coordinates=445499.9999767,492499.99998253', 'memory=500',
'max_distance=-1', 'output=vshed_0\r',
'target_elevation=1.75'] ended with error
Process ended with non-zero return code 1. See errors in the
(error) output.
(Wed Aug 10 13:48:32 2016) Command finished (2 sec)
Regards,
Adam Hoffritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160810/78d37fb0/attachment-0001.html>
