[GRASS-user] some questions on r.tile
Markus Neteler
neteler at osgeo.org
Wed Aug 10 11:00:53 PDT 2016
Hi
On Aug 10, 2016 4:34 PM, "Margherita Di Leo" <diregola at gmail.com> wrote:
> Hi,
> I have a doubt about the use of r.tile with overlap. r.tile without
overlap works without problem, however when I set an overlap, no matter how
large (have tried 400, 40 and 4 with same outcome) it gives me the error:
> ERROR: Illegal latitude for North
Which projection are you using?
I suspect latlong?
> How should I calculate my overlap and my tiles in order to avoid this
problem?
Please let us know more.. Perhaps also the command with parameters.
> Furthermore, is there a way to set a different rule for rows and columns?
say I want to generate vertical stripes that overlap each other for a
certain number of columns?
This will require a source code enhancement.
Markus
> Thanks for any hints
> Margherita Di Leo
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160810/737fa373/attachment.html>
