[GRASS-user] some questions on r.tile
Margherita Di Leo
diregola at gmail.com
Thu Aug 11 01:09:13 PDT 2016
Ciao Markus! Thanks for your answer,
On Wed, Aug 10, 2016 at 8:00 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi
> On Aug 10, 2016 4:34 PM, "Margherita Di Leo" <diregola at gmail.com> wrote:
> > ERROR: Illegal latitude for North
> Which projection are you using?
> I suspect latlong?
yes, correct.
> > How should I calculate my overlap and my tiles in order to avoid this
> problem?
> Please let us know more.. Perhaps also the command with parameters.
The data source I'm using is GMTED 2010 at 30 arc second spatial
resolution, global coverage --> created VRT --> linked via r.external -->
set g.region rast=<the whole mosaic>
g.region rast=bln300_mosaic -ap
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 89:59:59.5N
south: 70:00:00.5S
west: 179:59:59.5E
east: 179:59:59.5E
nsres: 0:00:30
ewres: 0:00:30
rows: 19200
cols: 43200
cells: 829440000
I wanted to try create 6 large tiles as a first tentative, to see how
r.tile works.
Then i calculate them like this:
rows: 19200 / 2 = 9600
cols: 43200 / 3 = 14400
r.tile input=bln300_mosaic output=tiled width=14400 height=9600 overlap=4
--v
hm..
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160811/fcf55108/attachment.html>
