[GRASS-user] GRASS_VERBOSE=-1
Micha Silver
micha at arava.co.il
Sat Aug 13 00:39:52 PDT 2016
------ Original Message ------ Subject: Re: [GRASS-user]
GRASS_VERBOSE=-1 Date: Fri, 12 Aug 2016 18:21:55 -0500 To: Micha Silver,
Grass User List From: Laurent C.
> Hello,
> One solution is to set the environment variable like this:
> os.environ['GRASS_VERBOSE'] = '3'
What I want to do is surpress the warning messages altogether.
Setting with:
os.environ['GRASS_VERBOSE'] = '-1'
doesn't seem to do anything.
> the other is to pass the verbosity as an argument to run_command(verbose=True)
> Cheers,
> Laurent
> 2016-08-12 9:56 GMT-05:00 Micha Silver <micha at arava.co.il>:
>> How do I use the VERBOSE=-1 option in a python script?
>> I am importing lists of rasters that do not have CRS info (grib2 format), so
>> I use the '-o' option to override CRS check. But the screen gets filled
>> with:
>> WARNING: Datum <unknown> not recognised by GRASS and no parameters found
>> WARNING: Over-riding projection check
>> and I miss the messages that I want to see.
>> Thanks
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
